High fps camera compatible with Deepstream4.0/Xavier
Can anyone recommend a single USB camera with high fps >100 that will work with Deepstream e.g. in yolo_tiny configuration? I know there is a list of supported cameras but ones like logitech c920 work but it isn’t listed (but it’s only 30fps)
Some of the high fps cameras I’ve found use MJPEG - is that supported?
We have E-Con See3CAM_CU135 in office and it can run in 640x480p120:
nvidia@nvidia-desktop:~$ v4l2-ctl --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
        Index       : 0
        Type        : Video Capture
        Pixel Format: 'UYVY'
                        Interval: Discrete 0.017s (60.000 fps)
                        Interval: Discrete 0.033s (30.000 fps)
                Size: Discrete 1920x1080
                Size: Discrete 3840x2160
                        Interval: Discrete 0.067s (15.000 fps)
                        Interval: Discrete 0.133s (7.500 fps)
                Size: Discrete 4208x3120
                        Interval: Discrete 0.111s (9.000 fps)
                        Interval: Discrete 0.222s (4.500 fps)
                Size: Discrete 4096x2160
                [b]Size: Discrete 640x480
                        Interval: Discrete 0.008s (120.000 fps)[/b]
FYR.
For higher resolution such as 1280x720p120, you may check Bayer sensors(run with nvarguscamerasrc) from our partners:
