I am using a logic tech camera that has these supported resolutions
Index : 0
Type : Video Capture
Pixel Format: 'YUYV'
Interval: Discrete 0.033s (30.000 fps)
Interval: Discrete 0.042s (24.000 fps)
Interval: Discrete 0.050s (20.000 fps)
Interval: Discrete 0.067s (15.000 fps)
Interval: Discrete 0.100s (10.000 fps)
Interval: Discrete 0.133s (7.500 fps)
Interval: Discrete 0.200s (5.000 fps)
Size: Discrete 1920x1080
Size: Discrete 2304x1296
Interval: Discrete 0.500s (2.000 fps)
Size: Discrete 2304x1536
Index : 1
Pixel Format: 'H264' (compressed)
Index : 2
Pixel Format: 'MJPG' (compressed)
I am modifying the sample configuration file of USB Camera that is provided in the deep stream package. It Works for cameras supporting resolution of 640x480 and lower but they do not seem to run when i set a higher resolution like 864x480.
What setting should I modify so that I can achieve maximum resolution lets sey 1920*1080
