There’s a similar hack for OSX.It may be useful to write a little OpenGL tool that does the bare minimum to keep the power mode in the right level.
It would only be clocking up to 275 MHz Core / 550 MHz Shader / 301 MHz Memory due to an ACPI related problem.
Last news I heard nvidia hope to get a fix into the next Beta driver.
Yeah, actually, if this was under 25W, available in low profile form factors, and could be powered without a PCI-Express plug, this would let me install CUDA devices in several of the computers I have around the lab that otherwise are unsuitable for a decent card.
Also, looks like someone has already announced they will be shipping laptops with the 480M:
http://web.eurocom.com/EC/ec_model_config1(1,202,0)
For those of you in the 17", 12 lbs. laptop/strength training device market. :)
Doesn’t look like it is:
Wow, the old Homestarrunner sketch about the 42 lbs laptop with 5 minutes of battery life is not as much of an exaggeration as I thought. :)
I have just taken delivery of a Kobalt Computers 15in machine with an i7 and GTX 285M. So far very good - the 285M is turning in very good numbers for CUDA and the i7 is doing nicely with GridMathematica. I will be using it for lectures and other demos.
The company is at
http://www.kobaltcomputers.co.uk/
and I have the G860. They have just launched the G875 with a 480M!
I considered the Sony F series but the 330 was just too weak, and likewise with most of the other consumer machines. The other custom supplier in the UK is www.novatech.co.uk who do a 260M in a 15 ish size.
Well I got some confirmation that the next beta driver release will address this issue.
Having an nVidia developer account is useful sometimes.
cool, but I want a notebook - not a space heater. ;)
Here’s my Mini Review of the Clevo W860CU barebone chassis (15.6 inch display diagonal)
as sold by mySN.eu (Schenker Notebooks), equipped with core i7 920XM and nVidia GTX285M.
We chose the Full HD display option.
Identical configurations are available from Sagernotebook.com (USA). Kobalt Computers (UK) and
other resellers internationally.
Cons:
-it’s relatively thick and heavy.
-the 3800mAh battery lasts for impressive 50 minutes. When idling. I did not dare to test under
load. There are no other battery options available, it seems.
-the Phoenix BIOS has virtually no options to configure.
-the ACPI BIOS, as shipped, does not appear expose the CPU’s C3 sleep state necessary to enable
the Core i7 “turbo” mode. Hence under Ubuntu 9.04 the CPU was limited to 2 GHz. We did not test
with Windows.
-the GTX 285M does not reach its full speed under Linux, which will be addressed by a future nVidia
driver update
-I did not like the keyboard much. Reminded me of a Sinclair Zx 80 Spectrum. ;)
-Fans can get noisy under load (and we weren’t even able to load it fully yet due to above
restrictions)
-Battery state and AC power indicator are only visible from the front, but not from the top. By default
there was no audible warning for low battery (this has to be enabled explicitly in the BIOS).
Pros:
-all hardware except the WLAN was detected by the not-so-fresh Ubuntu 9.04 (Jaunty Jackalope)
and working just fine. This was really the only reason we did not immediately return this notebook.
-Professional appearance (not having the usual “Gamer” gimmicks and decals)
Verdict: certainly a small monster, but very much crippled. We’re still looking for workarounds to
release the handbrakes.
Some updates on my hardware and driver troubles with this notebook:
The latest Beta Linux driver 256.29 finally fixed the problem with the notebook not reaching its nominal GPU speed.
mysn.eu (Schenker) contacted Clevo about the mysteriously missing C3 sleep state. Clevo flat out refused any
Linux support.
However I think the fix is this kernel patch from January 18 (part of kernels 2.6.32.7 and later)
https://bugzilla.kernel.org/attachment.cgi?..amp;action=diff
On Ubuntu 9.04 and older one may have to apply this manually (no more support after April this year).
It should also be available as a kernel update for Ubuntu 9.10 and it is part of Ubuntu 10.4 already.
Christian
Check out Eurocom , i think i recall its a canadian maker of notebook, similar to sager , but they do build even a few more high end features into their systems
an other alternative, if money isn’t the issue might be Orion, they do promise you could name your components and build a machine as ordered
