I would like to share my project: A multi-platform, multi-camera home security system using Jetson Nano, Jetson TX2 and raspberry pis.
Depending on your requirements, you can use:
Raspberry pi zero
Raspberry pi 3
Jetson Nano
Jetson TX2
The Pis are used for streaming video to the jetson or for basic motion detection, but the most useful aspects of security are enabled by object detection capabilities of Jetson Nano and TX2.
Thank you for your interest in this project. You are launching the script from the homesecurity/jetsonano directory, which is causing the error. The intended way of using the code is to launch the launcher script from the base directory. First, set the device variable in the launcher script to jetsonano with
nano launcher.sh
and then start the security cam with
bash launcher.sh
This script will setup your initial video storage directories and find the other dependencies from other directories. You will also have to provide an email address to send videos to and an email address with password to send the email from. These are to be provided as a text file âconfidential.txtâ in the base directory of the project. I will update the instructions on GitHub to show how to set up the confidential file. This file will never be tracked or uploaded to your GitHub repo if you are forking the project and developing it further.
I purchased the official models for each device, no clones. Some of these were bought from Japan where I currently live and some from India. I donât know if you would like to source from these places. I have run the project successfully on about 10 different raspberry pis from different vendors. I donât think the outcome depends on any specific vendor or model. For Jetsons, I believe all the products are the same, so you canât go wrong if you buy a genuine Jetson board.
Still, for your reference, the following US links should work:
countfile.txt is just a text file which stores the number of videos which have been processed. I have added the countfile to the latest commit. Please pull the changes and try again.
Just one thing, Iâve noticed that the securitycamnano.py prints an incorrect time, but the date is correct. Consequently, theres an incorrect timestamp when adding clockoverlay to your code.
Just to make sure, Iâve checked my system clock settings, and printed out the time on a seperate python file. However there is nothing wrong so far.
The timestamp is based on the location setting in common/config.py. The default setting is for âAsia/Kolkataâ. You can change it to be your location from the list of time zones here: https://en.wikipedia.org/wiki/List_of_tz_database_time_zones#List
Alternatively, you could comment out lines 15 and 16 in securitycamnano.py which set the location and timezones for the environment.
However, i now have a problem where the motion detector is too sensitive. Please look at the log below:
GST_ARGUS: PowerService: requested_clock_Hz=1008000
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
frame rate=30.160224466697443
Motion detected!!
Video recording started
Analyzing file mp4_videos/video5.mp4 to find human in video
frame rate=57.63114945336818
Motion detected!!
2019-11-22 19:42:06.435584: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcudnn.so.7
frame rate=58.93974052093108
Motion detected!!
2019-11-22 19:42:22.707303: W tensorflow/core/common_runtime/bfc_allocator.cc:237] Allocator (GPU_0_bfc) ran out of memory trying to allocate 1.02GiB with freed_by_count=0. The caller indicates that this is not a failure, but may mean that there could be performance gains if more memory were available.
2019-11-22 19:42:26.211926: W tensorflow/core/common_runtime/bfc_allocator.cc:237] Allocator (GPU_0_bfc) ran out of memory trying to allocate 1.02GiB with freed_by_count=0. The caller indicates that this is not a failure, but may mean that there could be performance gains if more memory were available.
2019-11-22 19:42:29.369057: W tensorflow/core/common_runtime/bfc_allocator.cc:237] Allocator (GPU_0_bfc) ran out of memory trying to allocate 2.05GiB with freed_by_count=0. The caller indicates that this is not a failure, but may mean that there could be performance gains if more memory were available.
frame rate=45.50420845449008
As you can see, it keeps picking up motion every time it finishes recording until the jetson nano runs out of memory. Do you know whats the problem?
Im trying to do the same exact home security and I want to know how to follow the steps. I want to have multiple cameras and have the Nvidia tx2 to detect it. Any suggestions and steps to get started.
Thank you for your interest in this project. There are a few things to take care of, to do multi-camera detection:
Your cameras should be connected to the same network as the tx2
You can either use multiple raspberry pis as camera or use your own IP cameras, the tx2 doesnât care. The only requirement is that you should provide the URLs of your streams in jetsontx2/tx2_surveillance.py script. The variables are url1 to url4. Be careful to also provide the resolution of the video streams in (height, width) format. Currently, the code can handle only streams of the same resolution, such as (360, 640) or (480, 640).
Finally, for low latency, please make sure that you have a good network router which can handle all the traffic from the cameras to the tx2. More detailed description of the network considerations are in the readme,
Is a configuration of four Raspberry Pi 4 devices with connected Raspberry Pi Camera Module v2s streaming video over Ethernet to a Jetson Nano for recording, object detection, and email notifications supported? If so, are any modifications required?
Hi 004,
Yes, this is supported. Although, the initial intention of the project was to use Jetson nano only with one camera, the code written for jetsontx2 also works on jetson nano. Please do the following:
Compile the SSD model on the nano. Run python3 jetsontx2/compile_ssd_mobilenet.py from the base directory of the project. This should be done only once.
Run common/stream_video.py on your raspis. The hostname of your pis should be pi1,pi2,pi3 & pi4. If your hostnames are different, you will need to provide the correct names in jetsontx2/tx2_surveillance.py (on lines 117 to 120).
If you have a display connected to your nano, the 4 camera streams will show up along with bounding box detections. Currently, email support is not enabled for TX2 part of the project, but you can modify the code to do so (using the jetson nano code as a guide). Fee free to get in touch if you need any help in doing it.
Thank you for taking the time to provide that guidance. This looks like an incredibly useful project and I look forward to trying it using those instructions.
Which python are you using? Basically, this is happening because jetsonano/securitycamnano.py script sets up some paths which the jetsonano/file_managernano.py should have access to when it is imported. This worked fine in all python versions that I have tried, but it does not in your case. So, I suggest that you add the following two lines to jetsonano/file_managernano.py after line 4:
