Hi everyone! First off, long time creeper and first time poster on here. Thank you everyone for posting on here. I use this forum everyday to learn how to work with the nano
Secondly (mainly), I’m trying to alter the code in the jetson hacks dual_camera.py file. I want to send the stitched together frames to the 264 encoder and then a udpsink. I’m able to open the camera and receive frames just fine, I just can’t send the frames out for processing.
This is how I open the videWriter:
out = cv2.VideoWriter(‘appsrc !’
‘omxh264enc control-rate=2 bitrate=4000000 !’
‘video/x-h264, stream-format=byte-stream !’
‘rtph264pay mtu=1400 !’
'udpsink host=192.168.0.110 port=5000 sync=false async=false ',
0, 60, (540,960*2) #reason for *2 is because this will use 2 frames hstack’d together
this is how the images are meant to be received:
gst-launch-1.0 udpsrc port=5000 ! application/x-rtp,encoding-name=H264,payload=96 ! rtph264depay ! h264parse ! queue ! avdec_h264 ! autovideosink sync=false async=false -e
and this is the output for the python script I’m getting:
nvbuf_utils: Could not get EGL display connection
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected…
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3264 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3264 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 120.000005 fps Duration = 8333333 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 3
Output Stream W = 1280 H = 720
seconds to Run = 0
Frame Rate = 59.999999
GST_ARGUS: PowerService: requested_clock_Hz=6048000
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
[ WARN:0] global /home/reed/opencv/modules/videoio/src/cap_gstreamer.cpp (933) open OpenCV | GStreamer warning: Cannot query video position: status=0, value=-1, duration=-1
Camera index = 1
Camera mode = 3
seconds to Run = 0
[ WARN:0] global /home/reed/opencv/modules/videoio/src/cap_gstreamer.cpp (1757) handleMessage OpenCV | GStreamer warning: Embedded video playback halted; module appsrc0 reported: Internal data stream error.
[ WARN:0] global /home/reed/opencv/modules/videoio/src/cap_gstreamer.cpp (1663) writeFrame OpenCV | GStreamer warning: Error pushing buffer to GStreamer pipeline
I’m not getting anything on the receiver side
any help would be appreciated!!
