Whenever you start a container and use the nvidia-container-runtime, there are libraries and files mapped into your container automatically. The configuration is located in /etc/nvidia-container-runtime/host-files-for-container.d/:
root@ubuntu:~# ls /etc/nvidia-container-runtime/host-files-for-container.d/
cuda.csv cudnn.csv l4t.csv tensorrt.csv visionworks.csv
For some containers cuda.csv is used, for others the l4t.csv is used, of others none of these are used. I was wondering if anybody knows what the decision making process is here. What config is used for which container? Documentation and insert your favorite search engine came up empty handed.
Hi @jeroen.torrekens, for JetPack 4.x all of the .csv files should get used by --runtime nvidia (as long as the container is derived from l4t-base). On JetPack 5.x, only l4t.csv gets used (because CUDA/cuDNN/TensorRT/ect are installed inside the containers on JetPack 5 for portability). Does that answer your question?
