texture texRef;
two buffers, buffer1 and buffer2 created with cudaMalloc()
CUDA Stream #1:
- async cudaMemCpy to buffer 1
- bind linear memory buffer1 to texRef
- run kernel using texRef for read access
CUDA Stream #2
- async cudaMemCpy to buffer 2
- bind linear memory buffer2 to texRef
Buffer 1 contains different input data than buffer 2.
Assuming overlapping kernel execution: What happens if stream 2 changes the texture reference TexRef to buffer 2, while Stream 1 is currently executing the kernel? Will the running kernel suddenly see different texture data - or does a texture binding remain constant while the kernel runs, independently from any cudaBindTexture() calls that may happen in the mean time?
s/threated/treated in thread title. Can’t edit that, it seems.
Christian
