please refer to developer guide about OP-TEE.
as you can see in flash configuration file, it’s secure-os partition reserved for OP-TEE.
unfortunately, we don’t test the use-case by disabling OP-TEE.
Hi Jerry, thanks for getting back to me. Please excuse my naivety but do you mind highlighting which flash configuration file you’re referring to? Thanks in advance.
assume you install the release image with SDKManger,
you’ll see the cfg file within the default installation path.
for example, ~/nvidia/nvidia_sdk/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/cfg/flash_t194_uefi_spi_sd_p3668.xml
As I understand from looking at this file, this config file determines how the SDKManager flashes/partitions the SD card or eMMC on the Xavier. Is this correct?
My follow-up question is, if I wish to disable OP-TEE (despite knowing it is untested), do I simply remove the above secure-os partition from the config file and try flashing the device via SDKManager?
If it is not possible to disable OP-TEE, how do I go about finding out the physical memory address range that is reserved for OP-TEE once the system is booted? I tried a few different strategies of finding this information such as taking a look through the source code of the bootloader, which I believe is here; however, I wasn’t able to find the answer to my question.
My ultimate objective is to either turn off OP-TEE or if that is not possible, avoid interacting with the memory region reserved for OP-TEE (which requires me to find out the physical memory address that has been reserved for OP-TEE).
that’s correct. this xml file list all the partition flash to the target. you may try removing the above secure-os partition from the config file, but you’ll need to perform flash.sh for image flashing manually.
may I know which l4t release version you’re working with.
this is source of UEFI, and it’s supported start with l4t-35.x release.
Thank you for confirming, I will try to flash the device manually after removing the secure-os partition from the config file and I will report back if I encounter any issues. Also, I’m using Jetson_Linux_R35.1.
please enter the $OUT/Linux_For_Tegra/bootloader folder, please also setting soft links for the binary file, $ ln -sf tos-mon-only_t194.img tos_t194.img
perform a full flash. $ sudo ./flash.sh jetson-xavier-nx-devkit-emmc mmcblk0p1
Hi Jerry, thank you for the detailed instructions. Once I’ve finished flashing the device, what would be the easiest way to confirm that OP-TEE is indeed turned off? Is there some variable in the UEFI bootloader that I can check to confirm that OP-TEE has been turned off?
