How can I get exact systemtime timestamp with gstreamer
Hi all,
I’m trying to get exact timestamp with my gstreamer.
When I check dts and pts with below command, it started when I enter command.
gst-launch-1.0 -ve v4l2src do-timestamp=true device=/dev/video1 ! “video/x-raw, format=(string)UYVY, width=(int)1920,height=(int)1080” ! nvvidconv ! “video/x-raw(memory:NVMM), format=(string)I420” ! fakesink silent=false
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (976 bytes, dts: 0:00:06.179406338, pts: 0:00:06.146063109, duration: 0:00:00.033333333, offset: 174, offset_end: 175, flags: 00000000 , meta: none) 0x7f8c017510
As I checked nvidia vi files, it set timestamp with ‘set_timestamp’ function in channel.c.
Can I get that timestamp with my gstreamer application?
Thanks in advance.
Looks like when you set v4l2src do-timestamp=true, it enables timestamp mechanism of gstreamer. For getting kernel timestamp, you may need to use jetson_multiemdia_api and refer to 12_camera_v4l2_cuda.
If you use r32.4.3, we have implemented nvv4l2camerasrc plugin and open source. You can download the source code and customize it to get kernel timestamp. The source code is in
https://developer.nvidia.com/embedded/L4T/r32_Release_v4.3/Sources/T210/public_sources.tbz2
Hi @DaneLLL
Thank you for your reply.
I’ll check jetson_multimedia_api and update it.
BTW, can I get the frame metadata info from v4l2src gstreamer command?
I thought I could get the timestamp from metadata but I couldn’t find the way.
Thanks,
Dongjin Ha.
Not sure but I think it is not implemented in default code. Suggest you go to gastreamer forum to get further information.
It is native gstreamer plugin and open source in
https://gstreamer.freedesktop.org/src/gst-plugins-good/
You can look at the source code and check if you can customize it and rebuild libgstvideo4linux2.so. We have build instructions in gstreamer user guide.
Hi @DaneLLL
Thank you for your comment.
Then can I supposed that there’s no way to get kernel timestamp from gstreamer except customizing gstreamer plugin?
Yes. I think it does not get kernel timestamp in default implementation.
