Getting timestams from gstreamer pipeline
I am trying to write a Python program that reads images from a GStreamer pipeline that uses nvarguscamerasrc and obtains accurate timestamps for each frame.
If I set silent=false on nvarguscamerasrc, it prints timestamps that according to the Argus library documentation is the number of nanoseconds since the start of the system’s monotonic clock.
How do I get a timestamp from a GStreamer pipeline that accurately represents these timestamps? I tried adding each samples DTS to the pipeline’s base_time. This yields numbers that are similar to the timestamps printed by nvarguscamerasrc, but are about 15 milliseconds later.
The test program I am using is http://www.bobberger.me/timestamp.py
Timestamp of each frame is stored in PTS in GstBuffer structure:
GstBuffer
Please check if you can read the value out in appsink
