GPU (T4)
• DeepStream Version
6.0.1
• TensorRT Version
8.2.1.8
470.57.02
questions
Hi.
I want to get gpu memory using python deepstream api in python gstreamer plugin.
There are pyds.get_nvds_buf_surface
method in API, but it return cpu numpy array.
I can get gpu memory by using c gstreamer plugin and c++ deepstream api in deepstream 4.
But I want to change from C to python by using python gstreamer plugin and python deepstream api in deepstream 6.
I used NvBufSurface
in c++, and there pyds.NvBufSurface
in API.
But, there are no sample for using pyds.NvBufSurface
I tried like using in c++, but it failed.
I think image is already in gpu nvmm memory. How can I get gpu memory from deepstream buffer in gstreamer plugin?
My Gstreamer pipeline
gst-launch-1.0
uridecodebin uri=file:///sample_video/1.mp4 !
nvvideoconvert nvbuf-memory-type=0 !
"video/x-raw(memory:NVMM),format=RGBA" !
m.sink_0 nvstreammux name=m nvbuf-memory-type=0 width=1920 height=1080 batch-size=1 !
gsttestplugin !
fakesink sync=1
My Python Gstreamer plugin (gsttestplugin)
import gi
gi.require_version("Gst", "1.0")
gi.require_version("GstBase", "1.0")
from gi.repository import GObject, Gst, GstBase
import pyds
class GstTestPlugin(GstBase.BaseTransform):
GST_PLUGIN_NAME = "gsttestplugin"
__gstmetadata__ = (
"TestPlugin",
"Plugin",
"Test Plugin",
"Test",
__gsttemplates__ = (
Gst.PadTemplate.new(
"src",
Gst.PadDirection.SRC,
Gst.PadPresence.ALWAYS,
Gst.Caps.new_any(),
"sink",
Gst.PadDirection.SINK,
Gst.Caps.new_any(),
def __init__(self):
super(GstTestPlugin, self).__init__()
def do_transform_ip(self, buffer: Gst.Buffer) -> Gst.FlowReturn:
res, map_info = buffer.map(Gst.MapFlags.READ)
if not res:
return Gst.FlowReturn.ERROR
surf = pyds.NvBufSurface.cast(hash(map_info.data))
print(surf.gpuId, surf.batchSize)
buffer.unmap(map_info)
return Gst.FlowReturn.OK
GObject.type_register(GstTestPlugin)
__gstelementfactory__ = (
GstTestPlugin.GST_PLUGIN_NAME,
Gst.Rank.NONE,
GstTestPlugin,
Log
Setting pipeline to PAUSED ...
Pipeline is PREROLLING ...
File "/opt/nvidia/deepstream/deepstream/lib/gst-plugins/python/gsttestplugin.py", line 41, in do_transform_ip
TypeError: cast(): incompatible function arguments. The following argument types are supported:
1. (self: capsule) -> pyds.NvBufSurface
2. (self: int) -> pyds.NvBufSurface
Invoked with: -6714784618403796263
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
Caught SIGSEGV
New clock: GstSystemClock
exec gdb failed: No such file or directory
Spinning. Please run 'gdb gst-launch-1.0 835' to continue debugging, Ctrl-C to quit, or Ctrl-\ to dump core.
^Chandling interrupt.
Interrupt: Stopping pipeline ...
Execution ended after 0:00:01.272463991
Setting pipeline to READY ...
^C
My Using Code in C api in deepstream 4.0
GstMapInfo in_map_info;
NvBufSurface* in_surf = nullptr;
memset(&in_map_info, 0, sizeof(in_map_info));
if (!gst_buffer_map(inbuf, &in_map_info, GST_MAP_READ))
return GST_FLOW_ERROR;
in_surf = reinterpret_cast<NvBufSurface*>(in_map_info.data);
gst_buffer_unmap(inbuf, &in_map_info);
