I’m creating a deepstream pipeline on my dGPU, and I’m trying to access the input frames and modify them (without opencv, I’m directly chaning the pixel values), this is part of the pipeline:
nvinfer → nvvideoconvert (nvbuf-memory-type = 3)
To access and edit the frames, I installed a probe at the source pad of the nvvideoconvert plugin:
GstPadProbeReturn srcProbe(GstPad *pad, GstPadProbeInfo *info) {
GstBuffer *inbuf;
GstMapInfo in_map_info;
NvBufSurface *surface = NULL;
NvDsBatchMeta *batch_meta = NULL;
NvDsFrameMeta *frame_meta = NULL;
NvDsMetaList * l_frame = NULL;
guint i = 0;
/*CHECK_CUDA_STATUS (cudaSetDevice (0), // gpu_id
"Unable to set cuda device");*/
memset (&in_map_info, 0, sizeof (in_map_info));
// All this following code is preparing the frame buffer to CPU space
inbuf = GST_PAD_PROBE_INFO_BUFFER(info);
inbuf = gst_buffer_make_writable(inbuf);
if (!gst_buffer_map (inbuf, &in_map_info, GST_MAP_WRITE)) {
g_print ("Error: Failed to map gst buffer\n");
return GST_PAD_PROBE_OK;
gst_buffer_unmap(inbuf, &in_map_info);
surface = (NvBufSurface *) in_map_info.data;
NvBufSurfaceMap(surface, -1, -1, NVBUF_MAP_WRITE);
// Modify the frame
NvBufSurfaceUnMap (surface, 0, 0);
Even though the nvvideoconvert plugin is set to memory type 3, when I try to access the surface I get this error:
nvbufsurface: mapping of memory type (2) not supported
I’ve looked at the sample, and mapping the surface in read mode like the sample code actually works:
NvBufSurfaceMap(surface, -1, -1, NVBUF_MAP_READ);
But I need to map it in NVBUF_MAP_WRITE mode, which causes the memory type error I specified earlier.
Should I map the surface in Read, then create a new nvbufsurface infer_buf and map it in read-write mode, modify it, then copy its content into the original with NvBufSurfTransform (inter_buf, surface, &transform_params); ?
from the error, NvBufSurfaceMap failed because memory type (2) not supported on dgpu.
please refer NvBufSurfaceMap sample opt\nvidia\deepstream\deepstream-6.2\sources\gst-plugins\gst-dsexample\gstdsexample_optimized.cpp, NVBUF_MEM_CUDA_UNIFIED is supported on dgpu.
Found the issue, it looks like I need to change the memory type or resolution of the nvvideoconvert plugin for the memory-type change to work, this needs to be fixed.
No problem, yes it is an issue with the deepstream plugin Gst-nvvideoconvert whereby if the input format/resolution of the plugin is the same as that of the output the memory-type conversion won’t take place.
Currently, a workaround for this changing either the resolution or the format of the output. You can mark this issue as resolved but this still needs to be fixed in Deepstream.
