Deepstream-app not running when more than 12 cams or 3 models
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 7.1
• TensorRT Version 10.6
• NVIDIA GPU Driver Version (valid for GPU only) 560.30.35
• Issue Type( questions, new requirements, bugs) Questions
I running NVIDIA-AI-IOT / deepstream_reference_apps version 7.1 modified deepstream_parallel_infer_app.cpp that body-pose related codes are removed.
Q1 app is not running
I have 3 difference yolox models.
If I run 1 models with 8 videos, it’s okay
If I run 2 models with 8 videos, it’s okay
But when I run 3 models with 9 videos or 2 models with 16 videos, its’ not okay..
Sometimes, 16vidoes with 2 models works..
But mostly it stuck at first 1 or 2 frame, shows few video frames and few green frames.
PERF shows 0 fps for all channels.
HW SPEC
cpu: Intel(R) Xeon(R) W-2245 CPU @ 3.90GH
gpu: nvidia rtx A4000
f21_config.yml.txt (3.6 KB)
f21_metamux.txt (1.2 KB)
deepstream_parallel_infer_app.cpp.txt (49.5 KB)
Q2 converting to cv::Mat
I tried to convert mat in this way. but It not working properly..
for (l_frame = batch_meta->frame_meta_list; l_frame != NULL; l_frame = l_frame->next) {
    NvDsFrameMeta *frame_meta = (NvDsFrameMeta *) (l_frame->data);
    NvDsMetaList *l_next = NULL;
    if (surface && surface->surfaceList[frame_meta->batch_id].dataPtr) {
      int width = surface->surfaceList[frame_meta->batch_id].width;
      int height = surface->surfaceList[frame_meta->batch_id].height;
      unsigned char *cpu_frame = (unsigned char *) malloc(width * height * 4);
      cudaMemcpy(cpu_frame, surface->surfaceList[frame_meta->batch_id].dataPtr,
                 width * height * 4, cudaMemcpyDeviceToHost);
      cv::Mat frame(height, width, CV_8UC4, cpu_frame);
     free(cpu_frame);
Also I tried to use get_converted_mat() from /opt/nvidia/deepstream/deepstream-7.1/sources/gst-plugins/gstdsexample.cpp.
However, I have no clue to find correspoding variabledsexample in parallel-infer..
Your help would be greatly appreciated… I sincerely seek your kind assistance.
Thank you
sorry for the late replay! DS7.1 requires R535. please make sure the component version meets the requirement in this table.
Thank you for the reply!
I will install matched version and try again!
And how can I extract frame data from nvbuffer?
my code is below
  NvBufSurface *surface = (NvBufSurface *)in_map_info.data;
    NvDsFrameMeta *frame_meta = (NvDsFrameMeta *)(l_frame->data);
    NvBufSurfaceParams *params = &surface->surfaceList[frame_meta->batch_id];
      uint32_t width = params->width;
      uint32_t height = params->height;
      uint32_t pitch = params->pitch;
      void *data = params->mappedAddr.addr;
      // pitch= 2048, height=1080, width=1920
      // data type is NVBUF_COLOR_FORMAT_NV12_709
      // in GPU Mem, color type YUV, buf size  Y (WH) UV (WH/2)
      size_t bufferSize = (width * height) + (width * height / 2); // Y (width x height) + UV (width x height / 2)
      uint8_t* dstCPUBuffer = new uint8_t[bufferSize];
      // use cudamemcpy2d since pitch != width
      cudaError_t err = cudaMemcpy2D(dstCPUBuffer, width, data, pitch, width, height * 3 / 2, cudaMemcpyDeviceToHost);
      cv::Mat frame(params->height, params->width, CV_8UC4, hostBuffer);
      cv::Mat bgr;
      cv::cvtColor(frame, bgr, cv::COLOR_RGBA2BGR);
and I got error
CUDA memcpy failed: invalid argument
Is there any correct way to get frame data on cpu?
I need cpu cv::Mat…
Thank you in advance :)
please refer to this sample for how to access nv12 by opencv.
I followed the code snippet and got this error.
Code
static GstPadProbeReturn
body_pose_gie_src_pad_buffer_probe(GstPad *pad, GstPadProbeInfo *info,
                          gpointer u_data)
  GstBuffer *buf = (GstBuffer *)info->data;
  NvDsMetaList *l_frame = NULL;
  NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta(buf);
  GstMapInfo in_map_info;
  if (!gst_buffer_map(buf, &in_map_info, GST_MAP_READ)) {
    g_print("Error: Failed to map gst buffer\n");
    return GST_PAD_PROBE_OK;
      if ( NvBufSurfaceMap (surface, -1, -1, NVBUF_MAP_READ) != 0 ){
        g_print("NvBufSurfaceMap failed..\n");
Result
nvbufsurface: mapping of memory type (2) not supported
I failed from the beginning with NvBufSurfaceMap.
According to the SDK API, NvBufSurfaceMap do
Maps hardware batched buffers to the HOST or CPU address space.
Valid for NVBUF_MEM_CUDA_UNIFIED type memory for dGPU and NVBUF_MEM_SURFACE_ARRAY and NVBUF_MEM_HANDLE type memory for Jetson.
How can I convert memory type of surface ?
Based on the example code from sample opt\nvidia\deepstream\deepstream-7.1\sources\gst-plugins\gst-dsexample\gstdsexample_optimized.cpp, I fixed my code as below.
                          gpointer u_data)
  gchar *msg = NULL;
  NvDsMetaList *l_obj = NULL;
  NvDsMetaList *l_user = NULL;
    NvBufSurfaceCreateParams create_params = { 0 };
    create_params.gpuId = 0;
    create_params.width = 1920;
    create_params.height = 1080;
    create_params.size = 0;
    create_params.colorFormat = NVBUF_COLOR_FORMAT_NV12_709;
    create_params.layout = NVBUF_LAYOUT_PITCH;
    create_params.memType = NVBUF_MEM_CUDA_UNIFIED;
  if (NvBufSurfaceCreate (&surface, 16, &create_params) != 0) {
          GST_ERROR ("Error: Could not allocate internal buffer for dsexample");
   // NvBufSurfaceMap is valid for NVBUF_MEM_CUDA_UNIFIED (3) type memory for dGPU
  NvBufSurfaceSyncForCpu (surface, 0, 0);
    //g_print("default %d pined %d device %d, unified %d, this %d\n",  NVBUF_MEM_DEFAULT ,  NVBUF_MEM_CUDA_PINNED, \
            NVBUF_MEM_CUDA_DEVICE, NVBUF_MEM_CUDA_UNIFIED, surface->memType);
     // default 0 pined 1 device 2, unified 3, this 2
    if (frame_meta->source_id < 4)
      guint height = surface->surfaceList[frame_meta->batch_id].height;
      guint width = surface->surfaceList[frame_meta->batch_id].width;
      cv::Mat nv12_mat = cv::Mat(height * 3 / 2, width, CV_8UC1, surface->surfaceList[frame_meta->batch_id].mappedAddr.addr[0], surface->surfaceList[frame_meta->batch_id].pitch);
      cv::Mat rgba_mat;
      cv::cvtColor(nv12_mat, rgba_mat, cv::COLOR_YUV2RGBA_NV12);
      std::string filename = "/workspace/tmpjpg/src" + std::to_string(frame_meta->source_id) + "_frame" + std::to_string(frame_meta->frame_num) + ".jpg";
      cv::imwrite(filename, rgba_mat);
  NvBufSurfaceUnMap(surface, 0, 0);
  gst_buffer_unmap(buf, &in_map_info);
and code works but image files are not save right…
its just 33kb and show green screen only…
Could you please help me ?
seems you create a new surface. please use the
NvBufSurface *surface = (NvBufSurface *)in_map_info.data; and make sure “sur->colorFormat” is nv12.
The color current color type is NVBUF_COLOR_FORMAT_NV12_709.
I checked color type by printing each variable.
                          gpointer u_data)
  NvBufSurfaceMap(surface, -1, -1, NVBUF_MAP_READ);
    if (frame_meta->source_id == 0)
      g_print("Current color format is  %d \n" , params->colorFormat);
      g_print("RGBA %d, NV12 %d NVBUF_COLOR_FORMAT_NV12_709 %d\n", NVBUF_COLOR_FORMAT_RGBA, NVBUF_COLOR_FORMAT_NV12, NVBUF_COLOR_FORMAT_NV12_709);
Current color format is  33
RGBA 19, NV12 6 NVBUF_COLOR_FORMAT_NV12_709 33
If I use NvBufSurfaceMap I got memory type error.
According to the SDK API I mentiond above, NvBufSurfaceMap only work with
NVBUF_MEM_CUDA_UNIFIED which has value 3 while current mem type is 2.
Thus I tried to convert memory type by following example /opt/nvidia/deepstream/deepstream-7.1/sources/gst-plugins/gst-dsexample/gstdsexample_optimized.cpp.
`NVBUF_MEM_CUDA_DEVICE` (2) --> `NVBUF_MEM_CUDA_UNIFIED` (3) by new surface params.
As a results, it didn’t work…
Bottom line,
  • color type is NV12 ( NVBUF_COLOR_FORMAT_NV12_709 33)
  • NvBufSurfaceMap failed due to memory type
What can I do …?
please add a nvideoconvert before nvdsexample to output `NVBUF_MEM_CUDA_UNIFIED type, here is a sample:
gst-launch-1.0 uridecodebin uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.mp4 ! nvvideoconvert nvbuf-memory-type=3 ! fakesink
I modified every nvbuf-memory-type in yml and it worked!!!
Thank you so much!!
