Save frames extracted from Deepstream pipeline in C++ OpenCV
• Hardware Platform (Jetson / GPU): Jetson Xavier AGX / NX, Orin AGX / NX
• DeepStream Version 6.0.1
• JetPack Version (valid for Jetson only) 4.6.3
• Issue Type( questions, new requirements, bugs) question
I’m trying to extract image frames from the metadata (similar to here except in C++ instead of python) and instead of saving them to disk, send them to my own custom gui.
Basically, in the probe callback from nvinfer, I would like to grab the image so I can do other things with it. The deepstream_image_meta_test example.c this post points to is close, however in the example, it’s just sends the ip_surf pointer to the function nvds_obj_enc_process which does all of the magic of extracting the image data, encoding it to jpeg and saving it. I need to know what that function does.
ip_surf is a NvBufSurface which according to documentation holds information about batched buffers. It looks like there could be a couple of places where the data might be:
ip_surf->surfaceList (NvBufSurfaceParams) -> dataPtr
ip_surf->surfaceList ->mappedAddr (NvBufSurfaceMappedAddr)->eglImage
ip_surf->surfaceList ->mappedAddr->addr
however both eglImage and addr are null pointers. dataPtr has something, but when I converted to BGR and save as a jpg (as a test) I just get garbage:
Code is:
 GstMapInfo inmap = GST_MAP_INFO_INIT;
 gst_buffer_map(buf, &inmap, GST_MAP_READ)
 NvBufSurface* ip_surf = (NvBufSurface*)inmap.data;
 gst_buffer_unmap(buf, &inmap);
 NvBufSurfaceParams* surf = ip_surf->surfaceList;
 cv::Mat image {(int)surf->height * 3 / 2, (int)surf->width, CV_8UC1, surf->dataPtr};
 cv::Mat image_bgr;
 cv::cvtColor(image, image_bgr, cv::COLOR_YUV2BGR_NV12);
cv::imwrite(fmt::format("frame{}.jpg", frame_meta->frame_num), image_bgr);
Any help would be appreciated.
You can refer to our source code: opt\nvidia\deepstream\deepstream\sources\gst-plugins\gst-dsexample\gstdsexample_optimized.cpp. There is a similar usage in the code.
static gboolean
convert_batch_and_push_to_process_thread (GstDsExample * dsexample,
    GstDsExampleBatch * batch) {
#ifdef WITH_OPENCV
    in_mat =
        cv::Mat (dsexample->processing_height, dsexample->processing_width,
        CV_8UC4,dsexample->inter_buf->surfaceList[i].mappedAddr.addr[0],
      dsexample->inter_buf->surfaceList[i].pitch);
I’m looking at that and it’s not clear what prep work is needed for that call to succeed. Looks like the steps are(loops and error checking removing for clarity)
NvBufSurfaceMemSet (dsexample->inter_buf, i, 0, 0);
err = NvBufSurfTransform (&dsexample->batch_insurf, dsexample->inter_buf,
      &dsexample->transform_params)
nvtxDomainRangePop (dsexample->nvtx_domain); // is this needed?
NvBufSurfaceMap (dsexample->inter_buf, i, 0, NVBUF_MAP_READ)
NvBufSurfaceSyncForCpu (dsexample->inter_buf, i,0);
Give me a day or two to work through that. Thanks,
OK. nvtxDomainRangePushEx and nvtxDomainRangePop are just for debug. You can ignore that. If you want to debug that plugin, you can use the following demo. opt\nvidia\deepstream\deepstream\sources\apps\sample_apps\deepstream-opencv-test.
So here’s what I have that appears to work:
tl::expected<cv::Mat, GstFlowReturn> get_opencv_mat(NvBufSurface& ip_surf, gint idx,
                                                      gdouble& ratio, gint processing_width,
                                                      gint processing_height) {
    // Not sure we actually need to copy the NvBufSurface arg above (originally named input_buf), so
    // instead of making a copy make it a reference and change the name to ip_surf so it can be used
    // directly?
    // then we don't need
    // NvBufSurface ip_surf;
    // ip_surf = *input_buf;
    // ip_surf.numFilled = ip_surf.batchSize = 1;
    // ip_surf.surfaceList = &(input_buf->surfaceList[idx]);
    // Where we're grabbing the entire image, I'm not sure any of this scaling stuff is needed from
    // here to the NvBufSurfTransformParams definition
    NvOSD_RectParams rect_params;
    // Scale the entire frame to processing resolution
    rect_params.left = 0;
    rect_params.top = 0;
    rect_params.width = processing_width;
    rect_params.height = processing_height;
    gint src_left = GST_ROUND_UP_2((int)rect_params.left);
    gint src_top = GST_ROUND_UP_2((int)rect_params.top);
    gint src_width = GST_ROUND_DOWN_2((int)rect_params.width);
    gint src_height = GST_ROUND_DOWN_2((int)rect_params.height);
    // Maintain aspect ratio
    double hdest = processing_width * src_height / (double)src_width;
    double wdest = processing_height * src_width / (double)src_height;
    guint dest_width, dest_height;
    if (hdest <= processing_height) {
      dest_width = processing_width;
      dest_height = hdest;
    } else {
      dest_width = wdest;
      dest_height = processing_height;
    // Configure transform session parameters for the transformation
    NvBufSurfTransformConfigParams transform_config_params;
    transform_config_params.compute_mode = NvBufSurfTransformCompute_Default;
    transform_config_params.gpu_id = gpu_id_;
    transform_config_params.cuda_stream = cuda_stream_;
    // Set the transform session parameters for the conversions executed in this thread.
    if (auto err = NvBufSurfTransformSetSessionParams(&transform_config_params);
        err != NvBufSurfTransformError_Success) {
      spdlog::error("NvBufSurfTransformSetSessionParams failed with error {}", err);
      return tl::unexpected {GST_FLOW_ERROR};
    // Calculate scaling ratio while maintaining aspect ratio
    ratio = MIN(1.0 * dest_width / src_width, 1.0 * dest_height / src_height);
    if ((rect_params.width == 0) || (rect_params.height == 0)) {
      spdlog::error("[get_opencv_mat]:crop_rect_params dimensions are zero");
#ifdef __aarch64__
    if (ratio <= 1.0 / 16 || ratio >= 16.0) {
      // Currently cannot scale by ratio > 16 or < 1/16 for Jetson
      spdlog::error("[get_opencv_mat] ratio {} not in range of [.0625 : 16]", ratio);
#endif
    // Set the transform ROIs for source and destination
    NvBufSurfTransformRect src_rect = {(guint)src_top, (guint)src_left, (guint)src_width,
                                       (guint)src_height};
    NvBufSurfTransformRect dst_rect = {0, 0, (guint)dest_width, (guint)dest_height};
    // Set the transform parameters
    NvBufSurfTransformParams transform_params;
    transform_params.src_rect = &src_rect;
    transform_params.dst_rect = &dst_rect;
    transform_params.transform_flag =
      NVBUFSURF_TRANSFORM_FILTER | NVBUFSURF_TRANSFORM_CROP_SRC | NVBUFSURF_TRANSFORM_CROP_DST;
    transform_params.transform_filter = NvBufSurfTransformInter_Default;
    // Memset the memory
    NvBufSurfaceMemSet(inter_buf_, idx, 0, 0);
    // spdlog::debug("Scaling and converting input buffer");
    // Transformation scaling+format conversion if any. Not sure if the transform is actually doing
    // anything other than a copy?  Maybe converting from NV12 to RGBA? Can we convert from NV12 to
    // BGR directly so only one conversion is needed?
    if (auto err = NvBufSurfTransform(&ip_surf, inter_buf_, &transform_params);
      spdlog::error("NvBufSurfTransform failed with error {} while converting buffer", err);
    // Map the buffer so that it can be accessed by CPU
    if (NvBufSurfaceMap(inter_buf_, idx, 0, NVBUF_MAP_READ) != 0) {
    // Cache the mapped data for CPU access
    NvBufSurfaceSyncForCpu(inter_buf_, idx, 0);
    // Use openCV to remove padding and convert RGBA to BGR. Can be skipped if
    // algorithm can handle padded RGBA data.
    const auto in_mat =
      cv::Mat(processing_height, processing_width, CV_8UC4,
              inter_buf_->surfaceList[0].mappedAddr.addr[0], inter_buf_->surfaceList[0].pitch);
    cv::Mat image_bgr;
    cv::cvtColor(in_mat, image_bgr, cv::COLOR_RGBA2BGR);
    if (NvBufSurfaceUnMap(inter_buf_, idx, 0)) {
    return image_bgr;
which is called in the src pad probe callback from nvinfer:
  static GstPadProbeReturn pgie_src_pad_buffer_probe(GstPad* pad, GstPadProbeInfo* info,
                                                     gpointer u_data) {
    GstCaps* caps = gst_pad_get_current_caps(pad);
    GstVideoInfo video_info = {};
    if (!gst_video_info_from_caps(&video_info, caps)) {
      logger_->error("[ProcessFrame] failed to get video_info");
      return (GstPadProbeReturn)GST_FLOW_ERROR;
    gst_caps_unref(caps);
    // NvDsDisplayMeta *display_meta = NULL;
    GstBuffer* buf = (GstBuffer*)info->data;
    if (!gst_buffer_map(buf, &inmap, GST_MAP_READ)) {
      GST_ERROR("input buffer mapinfo failed");
    if (inter_buf_ == nullptr) {
      logger_->info("[ProcessFrame] initializing Frame buffer");
      NvBufSurfaceCreateParams create_params;
      create_params.gpuId = gpu_id_;
      create_params.width = video_info.width;    // dsexample->processing_width;
      create_params.height = video_info.height;  // dsexample->processing_height;
      create_params.size = 0;
      create_params.colorFormat = NVBUF_COLOR_FORMAT_RGBA;
      create_params.layout = NVBUF_LAYOUT_PITCH;
#ifdef __aarch64__
      create_params.memType = NVBUF_MEM_DEFAULT;
#else
      create_params.memType = NVBUF_MEM_CUDA_UNIFIED;
#endif
      if (NvBufSurfaceCreate(&inter_buf_, 1, &create_params) != 0) {
        logger_->error("Error: Could not allocate internal buffer for dsexample");
        GST_ERROR("Error: Could not allocate internal buffer for dsexample");
    const int index = 0;  // at the moment our batch size == 1 so to simplify things, start there
                          // instead of looping through buffers, etc.
    double scale_ratio = 1.0;
    const auto frame_width = ip_surf->surfaceList[0].width;
    const auto frame_height = ip_surf->surfaceList[0].height;
    cv::Mat frame;
    if (const auto ret =
          vp->get_opencv_mat(*ip_surf, index, scale_ratio, frame_width, frame_height);
        !ret.has_value()) {
      return (GstPadProbeReturn)ret.error();
    } else {
      frame = ret.value();
If you have any suggestions for simplifying this (e.g. convert directly from nv12 to bgr) that would be great.
Basically, if you just want to save images, you can refer to the source code you attached:deepstream_image_meta_test.c.
If you just want to convert the colorformat, you can just use our NvBufSurfTransform API.
You can also use our nvvideoconvert plugin to convert that directly.
I’m not just interested in saving images, that was just the easiest thing to do for a proof of concept. It would be nice if the nvds_obj_enc_process function from that example was broken up so you could just pick the part of it you need (i.e. get the cv::Mat object).
Interesting comment about the nvvideoconvert. I do have that element in the pipeline. I would assume the callback we have now on the nvinfer element src pad could be moved to the nvvideoconvert src pad and I would assume I would still have access to all the metadata (i.e. detection bounding boxes, classes, etc.) as NVOSD is still downstream of nvvideoconvert and needs that metadata
We currently have no plans to open source nvds_obj_enc_process, but we have provided multiple parameter configurations to configure the output mode. You can refer to the soure code NvDsObjEncUsrArgs in nvds_obj_encode.h.
