Nvvideoconvert does not change memory-type if format/resolution is same between input/output?
• Hardware Platform (Jetson / GPU) dGPU
• DeepStream Version 6.1.1
• TensorRT Version
• NVIDIA GPU Driver Version (valid for GPU only) 515.65.01
• Issue Type( questions, new requirements, bugs) question
  • pipeline-A : [NV12 pipeline, nvbuf-memory-type=0] → nvvideovonert(nvbuf-memory-type=3) → “capsfilter format=NV12”
  • pipeline-B : [NV12 pipeline, nvbuf-memory-type=0] → nvvideovonert(nvbuf-memory-type=3) → “capsfilter format=RGBA”
pipeline-B output unified memory buffer while pipeline-A does not.
Is it expected behavior?
How to convert memory type without changing format or resolution?
How do you confirm whether the memory buffer is NVMM after the nvvideoconvert?
@yuweiw
I got nvbufsurface: mapping of memory type (0) not supported error when piepeline-A, while piepeline-B works in my custom app.
I use caps after videoconvert
  GstElement* capsfilter = gst_element_factory_make("capsfilter", "capsfilter");
  GstCaps* caps = gst_caps_new_simple("video/x-raw", "format", G_TYPE_STRING, "NV12", nullptr);
  GstCapsFeatures* features = gst_caps_features_new("memory:NVMM", nullptr);
  gst_caps_set_features(caps, 0, features);
  g_object_set(capsfilter, "caps", caps, nullptr);
  gst_caps_unref(caps);
Note that the last elemenet before nvvideovonert is streammux(new).
I tried the pipeline below, it works fine.
GST_DEBUG=3 gst-launch-1.0 -v videotestsrc ! 'video/x-raw,format=RGBA' !  nvvideoconvert nvbuf-memory-type=3 name=converter1 ! 'video/x-raw(memory:NVMM),format=(string)RGBA' !  smuxer.sink_0 nvstreammux name=smuxer  ! fakesink
Could you attach your 2 whole gst-launch-1.0 commands? Thanks
@yuweiw
my app is C/C++.
gst-launch command which imitate the app would be.
export USE_NEW_STREAMMUX=yes
#pipeline-A
gst-launch-1.0 -v videotestsrc ! 'video/x-raw,format=NV12' !  nvvideoconvert nvbuf-memory-type=0 ! 'video/x-raw(memory:NVMM),format=(string)NV12' ! smuxer.sink_0 nvstreammux name=smuxer width=1280 height=720 batch-size=1 ! nvvideoconvert nvbuf-memory-type=3 ! 'video/x-raw(memory:NVMM),format=(string)NV12' ! fakesink
#pipeline-B
gst-launch-1.0 -v videotestsrc ! 'video/x-raw,format=NV12' !  nvvideoconvert nvbuf-memory-type=0 ! 'video/x-raw(memory:NVMM),format=(string)NV12' ! smuxer.sink_0 nvstreammux name=smuxer width=1280 height=720 batch-size=1 ! nvvideoconvert nvbuf-memory-type=3 ! 'video/x-raw(memory:NVMM),format=(string)RGBA' ! fakesink
I belive
  • nvbuf-memory-type at fakesink of pipeline-A is 0
  • nvbuf-memory-type at fakesink of pipeline-B is 3
Could you attach your minimized app code? We can verify it from the code. Thanks
Understood. I will do it when I have time.
Hi @ta.sugiyama , I have confirmed that nvvideoconvert cannot change the memType if the format&resolution is same between input/output. We’ll check this problem.
Also, could you tell us your specific use scenario?
@yuweiw
OK. We do not support this situation with nvvideoconvert at present. We’ll check this probelm and add this to our roadmap. Thanks
I got it.
BTW, nvstreammux-new should support nvbuf-memory-type (old one support it)
