Hi Fiona,
Thanks for your time.
First of all, I apologize, I forgot to add the capsfilter after nvvideoconvert, in this case it’s working fine, only if the nvvideoconvert is after nvstreammux.
In this case I can receive CUDA Unified buffer in appsink correctly.
But I wonder why it doesn’t work if nvvideoconvert is before new nvstreammux?
Look at this code and the resulting pipeline:
Makefile
CUDA_VER ?= 11.6
APP := simple-pipeline-test
NVDS_VERSION := 6.1
LIB_INSTALL_DIR ?= /opt/nvidia/deepstream/deepstream-$(NVDS_VERSION)/lib/
SRCS := $(wildcard *.cpp)
PKGS := gstreamer-1.0 gstreamer-app-1.0
OBJS := $(SRCS:.cpp=.o)
CXXFLAGS += -I../../../includes \
-I /usr/local/cuda-$(CUDA_VER)/include \
-I /opt/nvidia/deepstream/deepstream-$(NVDS_VERSION)/sources/includes
CXXFLAGS += $(shell pkg-config --cflags $(PKGS)) --std=c++17 -DDEBUG -g -gdwarf-3
LIBS := $(shell pkg-config --libs $(PKGS)) \
-L/usr/local/cuda-$(CUDA_VER)/lib64/ -lcudart \
-L$(LIB_INSTALL_DIR) -lnvdsgst_meta -lnvds_meta -lnvbufsurface \
-lcuda -lstdc++fs -Wl,-rpath,$(LIB_INSTALL_DIR)
all: $(APP)
%.o: %.cpp Makefile
$(CXX) -c -o $@ $(CXXFLAGS) $<
$(APP): $(OBJS) Makefile
$(CXX) -o $(APP) $(OBJS) $(LIBS)
clean:
rm -rf $(OBJS) $(APP)
main.cpp
#include <nvbufsurface.h>
#include <gstnvdsmeta.h>
#include <gst/gst.h>
#include <gst/app/gstappsink.h>
#include <gstreamer-1.0/gst/rtsp/gstrtsptransport.h>
#include <filesystem>
#include <fstream>
#include <iostream>
#include <string_view>
#include <cassert>
#include <cstdlib>
#include <cstring>
GstElement* g_pipeline = nullptr;
void write_nvstreammux_config(const std::filesystem::path& path)
std::ofstream f(path);
assert(f.is_open());
f << "[property]" << std::endl;
f << "algorithm-type=1" << std::endl;
f << "overall-max-fps-n=5" << std::endl;
f << "overall-max-fps-d=1" << std::endl;
f << "overall-min-fps-n=5" << std::endl;
f << "overall-min-fps-d=1" << std::endl;
f << "max-same-source-frames=1" << std::endl;
f << "adaptive-batching=1" << std::endl;
f << "max-fps-control=0" << std::endl;
f.close();
void write_nvinfer_config(const std::filesystem::path& path,
const std::filesystem::path& model_dir)
f << "gpu-id=0" << std::endl;
f << "net-scale-factor=0.0039215697906911373" << std::endl;
f << std::endl;
f << "input-dims=3;544;960;0" << std::endl;
f << "uff-input-blob-name=input_1" << std::endl;
f << "batch-size=16" << std::endl;
f << "model-color-format=0" << std::endl;
f << "num-detected-classes=3" << std::endl;
f << "cluster-mode=1" << std::endl;
f << "interval=0" << std::endl;
f << "gie-unique-id=1" << std::endl;
f << "output-blob-names=output_bbox/BiasAdd;output_cov/Sigmoid" << std::endl;
f << std::endl;
f << "tlt-model-key=tlt_encode" << std::endl;
f << "tlt-encoded-model=" << (model_dir / "resnet34_peoplenet_pruned.etlt").c_str() << std::endl;
f << "model-engine-file=" << (model_dir / "resnet34_peoplenet_pruned.etlt_b16_gpu0_fp16.engine").c_str() << std::endl;
f << "labelfile-path=" << (model_dir / "labels.txt").c_str() << std::endl;
f << std::endl;
f << "network-mode=2" << std::endl;
f << "network-type=0" << std::endl;
f << "process-mode=1" << std::endl;
f << std::endl;
f << "[class-attrs-all]" << std::endl;
f << "pre-cluster-threshold=0.4" << std::endl;
f << "eps=0.7" << std::endl;
f << "minBoxes=1" << std::endl;
f << "nms-iou-threshold=0.6" << std::endl;
f.close();
gboolean print_cap(GstCapsFeatures* /*features*/, GstStructure* structure, gpointer /*user_data*/)
gchar* s = gst_structure_to_string(structure);
std::cout << "caps: " << s << std::endl;
g_free(s);
return TRUE;
void on_decodebin_pad_added(GstElement* /*element*/, GstPad* pad, gpointer data)
std::cout << "[on_decodebin_pad_added]" << std::endl;
GstElement* videoconvert = reinterpret_cast<GstElement*>(data);
GstCaps* caps = gst_pad_get_current_caps(pad);
gst_caps_foreach(caps, print_cap, nullptr);
gst_caps_unref(caps);
GstPad* sink_pad(gst_element_get_static_pad(videoconvert, "sink"));
gst_pad_link(pad, sink_pad);
gst_object_unref(sink_pad);
void print_batch_meta(NvDsBatchMeta* batch_meta, bool print_detections)
for (NvDsFrameMetaList* frame_meta_list = batch_meta->frame_meta_list;
frame_meta_list != nullptr;
frame_meta_list = frame_meta_list->next)
NvDsFrameMeta* frame_meta = static_cast<NvDsFrameMeta*>(frame_meta_list->data);
if (frame_meta != nullptr)
std::cout
<< "[on_new_sample] streammux_source_id="
<< frame_meta->source_id
<< ", frame_num="
<< frame_meta->frame_num
<< std::endl;
if (print_detections)
for (NvDsObjectMetaList* obj_meta_list = frame_meta->obj_meta_list;
obj_meta_list != nullptr;
obj_meta_list = obj_meta_list->next)
NvDsObjectMeta* nv_ds_object_meta = static_cast<NvDsObjectMeta*>(obj_meta_list->data);
if (nv_ds_object_meta == nullptr)
continue;
std::cout
<< "[on_new_sample] "
<< nv_ds_object_meta->unique_component_id
<< nv_ds_object_meta->class_id
<< nv_ds_object_meta->confidence
<< nv_ds_object_meta->obj_label
<< std::endl;
GstFlowReturn on_new_sample(GstElement* element, gpointer /*user_data*/)
GstSample* sample = gst_app_sink_pull_sample(GST_APP_SINK_CAST(element));
assert(sample != nullptr);
GstBuffer* buffer = gst_sample_get_buffer(sample);
assert(buffer != nullptr);
GstMapInfo map_info;
std::memset(&map_info, 0, sizeof(map_info));
if (gst_buffer_map(buffer, &map_info, GST_MAP_READ))
NvBufSurface* surface = reinterpret_cast<NvBufSurface*>(map_info.data);
if (surface->memType == NVBUF_MEM_CUDA_UNIFIED)
std::cout << "MEMORY TYPE: NVBUF_MEM_CUDA_UNIFIED" << std::endl;
if (NvBufSurfaceMap(surface, -1, -1, NVBUF_MAP_READ) == 0)
if (NvBufSurfaceUnMap(surface, -1, 0) == 0)
std::cout << "NvBufSurfaceMap/NvBufSurfaceUnMap successful" << std::endl;
else if (surface->memType == NVBUF_MEM_DEFAULT)
std::cout << "MEMORY TYPE: NVBUF_MEM_DEFAULT" << std::endl;
else
std::cout << "MEMORY TYPE: " << surface->memType << std::endl;
gst_buffer_unmap(buffer, &map_info);
NvDsBatchMeta* batch_meta = gst_buffer_get_nvds_batch_meta(buffer);
if (batch_meta != nullptr && batch_meta->num_frames_in_batch > 0)
print_batch_meta(batch_meta, !false);
gst_sample_unref(sample);
return GST_FLOW_OK;
gboolean bus_call(GstBus* /*bus*/, GstMessage* msg, gpointer data)
using namespace std::string_view_literals;
GMainLoop* loop = reinterpret_cast<GMainLoop*>(data);
switch (GST_MESSAGE_TYPE(msg))
case GST_MESSAGE_EOS:
std::cout << "End of stream" << std::endl;
g_main_loop_quit(loop);
break;
case GST_MESSAGE_ERROR:
gchar* debug;
GError* error;
gst_message_parse_error(msg, &error, &debug);
std::cerr
<< "Error from element "
<< GST_OBJECT_NAME(msg->src)
<< error->message
<< std::endl;
if (debug)
std::cerr << "Error details " << debug << std::endl;
g_free(debug);
g_error_free(error);
break;
case GST_MESSAGE_STATE_CHANGED:
GstState old_state;
GstState new_state;
gst_message_parse_state_changed(msg, &old_state, &new_state, nullptr);
const char* name = GST_OBJECT_NAME(msg->src);
if (name == "pipeline"sv && new_state == GST_STATE_PLAYING)
gst_debug_bin_to_dot_file(GST_BIN(g_pipeline), GST_DEBUG_GRAPH_SHOW_ALL, "pipeline");
break;
default:
break;
return TRUE;
int main(int argc, char* argv[])
if (argc != 3)
std::cerr << "Usage: simple-pipeline-test MODEL_ABSOLUTE_DIR FILE_PATH" << std::endl;
return 1;
write_nvstreammux_config("/tmp/nvstreammux-config.txt");
write_nvinfer_config("/tmp/nvinfer-config.txt", argv[1]);
gst_init(&argc, &argv);
GstElement* src = gst_element_factory_make("filesrc", "src");
GstElement* decodebin = gst_element_factory_make("decodebin", "decodebin");
GstElement* videorate = gst_element_factory_make("videorate", "videorate");
GstElement* videoconvert = gst_element_factory_make("nvvideoconvert", "videoconvert");
GstElement* capsfilter = gst_element_factory_make("capsfilter", "capsfilter");
GstElement* streammux = gst_element_factory_make("nvstreammux", "streammux");
GstElement* infer = gst_element_factory_make("nvinfer", "infer");
GstElement* sink = gst_element_factory_make("appsink", "sink");
GstElement* pipeline = gst_pipeline_new("pipeline");
assert(src != nullptr);
assert(decodebin != nullptr);
assert(videorate != nullptr);
assert(streammux != nullptr);
assert(videoconvert != nullptr);
assert(capsfilter != nullptr);
assert(infer != nullptr);
assert(sink != nullptr);
assert(pipeline != nullptr);
g_pipeline = pipeline;
g_object_set(src, "location", argv[2], nullptr);
g_object_set(videorate, "drop-only", TRUE, "max-rate", 2, nullptr);
g_object_set(videoconvert, "nvbuf-memory-type", 3, nullptr);
GstCaps* caps = gst_caps_new_simple("video/x-raw", "format", G_TYPE_STRING, "RGBA", nullptr);
GstCapsFeatures* features = gst_caps_features_new("memory:NVMM", nullptr);
gst_caps_set_features(caps, 0, features);
g_object_set(capsfilter, "caps", caps, nullptr);
const char* new_streammux = std::getenv("USE_NEW_NVSTREAMMUX");
if (new_streammux != nullptr && new_streammux == "yes"sv)
g_object_set(streammux,
"attach-sys-ts", TRUE,
"batch-size", 1,
"sync-inputs", TRUE,
"max-latency", 200000000,
"num-surfaces-per-frame", 1,
"config-file-path", "/tmp/nvstreammux-config.txt",
nullptr);
else
"width", 1920,
"height", 1080,
"batched-push-timeout", 200000,
"live-source", TRUE,
"enable-padding", TRUE,
"buffer-pool-size", 4,
"batch-size", 1,
nullptr);
g_object_set(infer, "config-file-path", "/tmp/nvinfer-config.txt", nullptr);
g_object_set(sink,
"emit-signals", TRUE,
"async", FALSE,
"sync", FALSE,
"drop", TRUE,
"wait-on-eos", FALSE,
"enable-last-sample", FALSE,
"max-buffers", 10,
nullptr);
g_signal_connect(decodebin, "pad-added", G_CALLBACK(on_decodebin_pad_added), videorate);
g_signal_connect(sink, "new-sample", G_CALLBACK(on_new_sample), nullptr);
gst_bin_add_many(GST_BIN(pipeline),
src,
decodebin,
videorate,
videoconvert,
capsfilter,
streammux,
infer,
sink,
nullptr);
GstPad* src_pad = gst_element_get_static_pad(capsfilter, "src");
assert(src_pad != nullptr);
GstPad* sink_pad = gst_element_get_request_pad(streammux, "sink_0");
assert(sink_pad != nullptr);
assert(gst_pad_link(src_pad, sink_pad) == GST_PAD_LINK_OK);
gst_object_unref(src_pad);
assert(gst_element_link_many(src, decodebin, nullptr));
assert(gst_element_link_many(videorate, videoconvert, capsfilter, nullptr));
assert(gst_element_link_many(streammux, infer, sink, nullptr));
GMainLoop* loop = g_main_loop_new(nullptr, FALSE);
GstBus* bus = gst_pipeline_get_bus(GST_PIPELINE(pipeline));
guint bus_watch_id = gst_bus_add_watch(bus, bus_call, loop);
gst_object_unref(bus);
gst_element_set_state(pipeline, GST_STATE_PLAYING);
std::cout << "Running..." << std::endl;
g_main_loop_run(loop);
std::cout << "Returned, stopping playback" << std::endl;
gst_element_set_state(pipeline, GST_STATE_NULL);
std::cout << "Deleting pipeline" << std::endl;
gst_object_unref(GST_OBJECT(pipeline));
g_source_remove(bus_watch_id);
g_main_loop_unref(loop);
return 0;
mkdir model
wget https://api.ngc.nvidia.com/v2/models/nvidia/tao/peoplenet/versions/pruned_v2.3/files/resnet34_peoplenet_pruned.etlt -O model/resnet34_peoplenet_pruned.etlt
wget https://api.ngc.nvidia.com/v2/models/nvidia/tao/peoplenet/versions/pruned_v2.3/files/labels.txt -O model/labels.txt
nvidia-docker container run -it --rm -v $(pwd):/app -u $(id -u):$(id -g) --workdir=/app nvcr.io/nvidia/deepstream:6.1-devel
make
USE_NEW_NVSTREAMMUX=yes ./simple-pipeline-test $(pwd)/model video.mp4
The resulting buffer is not CUDA Unified as I specified in nvvideoconvert.
Does new nvstreammux modify the input buffer format? I would expect the buffer to be RGBA+CUDA Unified until the appsink.
