Wen I run with new streammux export USE_NEW_NVSTREAMMUX=yes this warning spams the console:
0:03:36.191837381 4429 0x7e968c118d20 WARN nvvideoconvert gstnvvideoconvert.c:1962:gst_nvvideoconvert_fixate_caps:<decoder_nvvidconv_17f493db-4d17-4c9f-b474-0a5af87d2376> gpu-id property is set based on SRC caps. Property config setting (if any) is overridden!!
If I run the same pipeline but with export USE_NEW_NVSTREAMMUX=no it runs without warning.
I need to use the new Streammux, How can I prevent these warnings from happening?
I’ve used nvvideoconvert nvbuf-memory-type=2 and the warning is still there.
We have production devices with 1 or more GPUs, even though the gpu-id is assigned programmatically to ALL elements in the software, this happens even if the device has a single GPU.
My question is what in the caps do I need to set (filter)?
Why is there no implementation in the sample apps with the new-nvstreammux?
I see. But there is more to it, It appears as if the buffers are “auto” allocating memory and causing CUDA errors. As the behaviour when using NEW_NVSTREAMMUX is also printing:
gstnvtracker: Unable to acquire a user meta buffer. Try increasing user-meta-pool-size
Also sometimes it errors on CUDA level:
0:01:44.554063302 18 0x7f02d4004180 ERROR nvinfer gstnvinfer.cpp:1209:get_converted_buffer:<detector> cudaMemset2DAsync failed with error cudaErrorIllegalAddress while converting buffer
0:01:44.554179577 18 0x7f02d4004180 WARN nvinfer gstnvinfer.cpp:1560:gst_nvinfer_process_full_frame:<detector> error: Buffer conversion failed
ERROR: nvdsinfer_context_impl.cpp:1848 Failed to synchronize on cuda copy-coplete-event, cuda err_no:700, err_str:cudaErrorIllegalAddress
ERROR: nvdsinfer_context_impl.cpp:1681 Preprocessor transform input data failed., nvinfer error:NVDSINFER_CUDA_ERROR
0:01:44.555175346 18 0x7f02d40040c0 WARN nvinfer gstnvinfer.cpp:2435:gst_nvinfer_output_loop:<detector> error: Failed to dequeue output from inferencing. NvDsInferContext error: NVDSINFER_CUDA_ERROR
0:01:44.556277399 18 0x3d3b300 WARN nvinfer gstnvinfer.cpp:1404:gst_nvinfer_input_queue_loop:<reid> error: Failed to queue input batch for inferencing
0:01:44.565906953 18 0x7f02d40040c0 WARN nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger:<detector> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::releaseBatchOutput() <nvdsinfer_context_impl.cpp:1884> [UID = 1]: Tried to release an outputBatchID which is already with the context
0:01:44.568965716 18 0x7efebc02c5e0 ERROR v4l2allocator gstv4l2allocator.c:784:gst_v4l2_allocator_start:<decoder_decoder_f572db21-081b-4935-97b3-687120d6c6af:pool:sink:allocator> error requesting 2 buffers: Unknown error -1
0:01:44.569045160 18 0x7efebc02c5e0 ERROR v4l2bufferpool gstv4l2bufferpool.c:1217:gst_v4l2_buffer_pool_start:<decoder_decoder_f572db21-081b-4935-97b3-687120d6c6af:pool:sink> we received 0 buffer from device '/dev/nvidia0', we want at least 2
0:01:44.569058111 18 0x7efebc02c5e0 ERROR bufferpool gstbufferpool.c:559:gst_buffer_pool_set_active:<decoder_decoder_f572db21-081b-4935-97b3-687120d6c6af:pool:sink> start failed
0:01:44.632091546 18 0x7efeb43bc1e0 ERROR v4l2allocator gstv4l2allocator.c:784:gst_v4l2_allocator_start:<decoder_decoder_6d909893-5064-41a3-8a10-0a8c7b840d5b:pool:sink:allocator> error requesting 2 buffers: Unknown error -1
0:01:44.632835176 18 0x7efeb43bc1e0 ERROR v4l2bufferpool gstv4l2bufferpool.c:1217:gst_v4l2_buffer_pool_start:<decoder_decoder_6d909893-5064-41a3-8a10-0a8c7b840d5b:pool:sink> we received 0 buffer from device '/dev/nvidia0', we want at least 2
0:01:44.632850379 18 0x7efeb43bc1e0 ERROR bufferpool gstbufferpool.c:559:gst_buffer_pool_set_active:<decoder_decoder_6d909893-5064-41a3-8a10-0a8c7b840d5b:pool:sink> start failed
0:01:45.551866572 18 0x7efeec0604c0 ERROR v4l2allocator gstv4l2allocator.c:784:gst_v4l2_allocator_start:<decoder_decoder_9071a25a-f1b0-47cb-b597-2dee558f8c5d:pool:sink:allocator> error requesting 2 buffers: Unknown error -1
0:01:45.551898260 18 0x7efeec0604c0 ERROR v4l2bufferpool gstv4l2bufferpool.c:1217:gst_v4l2_buffer_pool_start:<decoder_decoder_9071a25a-f1b0-47cb-b597-2dee558f8c5d:pool:sink> we received 0 buffer from device '/dev/nvidia0', we want at least 2
0:01:45.551915921 18 0x7efeec0604c0 ERROR bufferpool gstbufferpool.c:559:gst_buffer_pool_set_active:<decoder_decoder_9071a25a-f1b0-47cb-b597-2dee558f8c5d:pool:sink> start failed
0:01:46.235460654 18 0x7eff14660300 ERROR v4l2allocator gstv4l2allocator.c:784:gst_v4l2_allocator_start:<decoder_decoder_620a95ef-48e2-4286-bbd2-7eb1c350db59:pool:sink:allocator> error requesting 2 buffers: Unknown error -1
0:01:46.235514308 18 0x7eff14660300 ERROR v4l2bufferpool gstv4l2bufferpool.c:1217:gst_v4l2_buffer_pool_start:<decoder_decoder_620a95ef-48e2-4286-bbd2-7eb1c350db59:pool:sink> we received 0 buffer from device '/dev/nvidia0', we want at least 2
0:01:46.235530324 18 0x7eff14660300 ERROR bufferpool gstbufferpool.c:559:gst_buffer_pool_set_active:<decoder_decoder_620a95ef-48e2-4286-bbd2-7eb1c350db59:pool:sink> start failed
0:01:46.248502406 18 0x7efef8149b60 ERROR v4l2allocator gstv4l2allocator.c:784:gst_v4l2_allocator_start:<decoder_decoder_f04e3406-f2f5-47e8-8895-93dbccc92081:pool:sink:allocator> error requesting 2 buffers: Unknown error -1
0:01:46.248554437 18 0x7efef8149b60 ERROR v4l2bufferpool gstv4l2bufferpool.c:1217:gst_v4l2_buffer_pool_start:<decoder_decoder_f04e3406-f2f5-47e8-8895-93dbccc92081:pool:sink> we received 0 buffer from device '/dev/nvidia0', we want at least 2
0:01:46.248565761 18 0x7efef8149b60 ERROR bufferpool gstbufferpool.c:559:gst_buffer_pool_set_active:<decoder_decoder_f04e3406-f2f5-47e8-8895-93dbccc92081:pool:sink> start failed
0:01:46.253266687 18 0x7efef8149aa0 ERROR v4l2allocator gstv4l2allocator.c:784:gst_v4l2_allocator_start:<decoder_decoder_fdf3ba50-98d6-42d9-a59c-666e5c1085a2:pool:sink:allocator> error requesting 2 buffers: Unknown error -1
0:01:46.254441193 18 0x7efef8149aa0 ERROR v4l2bufferpool gstv4l2bufferpool.c:1217:gst_v4l2_buffer_pool_start:<decoder_decoder_fdf3ba50-98d6-42d9-a59c-666e5c1085a2:pool:sink> we received 0 buffer from device '/dev/nvidia0', we want at least 2
0:01:46.254496383 18 0x7efef8149aa0 ERROR bufferpool gstbufferpool.c:559:gst_buffer_pool_set_active:<decoder_decoder_fdf3ba50-98d6-42d9-a59c-666e5c1085a2:pool:sink> start failed
2024-02-21 03:18:02.208 ERROR <_bus_call@inference_pipeline.py> [1] gst-resource-error-quark: Failed to allocate required memory. (13): gstv4l2videodec.c(2252): gst_v4l2_video_dec_handle_frame (): /GstPipeline:inference_pipeline_1/GstBin:decode_bin_f572db21-081b-4935-97b3-687120d6c6af/nvv4l2decoder:decoder_decoder_f572db21-081b-4935-97b3-687120d6c6af:
Again, all of this won’t happen using the legacy streammux.
I was relating the issues with switching the GPU allocation, but probably is something else, as you say there is no need for conversion.
Lastly, the convertor that we use on our production pipeline, will also rotate the stream (if needed) so I do need a convertor somewhere in the decoding pipeline.
Important to note that our production code runs with python.
0:00:01.370973270 63357 0x5aae936f8ea0 WARN nvvideoconvert gstnvvideoconvert.c:1957:gst_nvvideoconvert_fixate_caps:<conv1> nvbuf-memory-type property is set based on SRC caps. Property config setting (if any) is overridden!!
0:00:01.370982720 63357 0x5aae936f8ea0 WARN nvvideoconvert gstnvvideoconvert.c:1962:gst_nvvideoconvert_fixate_caps:<conv1> gpu-id property is set based on SRC caps. Property config setting (if any) is overridden!!
0:00:01.371155690 63357 0x7b2508028520 WARN v4l2bufferpool gstv4l2bufferpool.c:1565:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:src> Driver should never set v4l2_buffer.field to ANY
0:00:01.371545270 63357 0x7b2508028520 WARN nvvideoconvert gstnvvideoconvert.c:1957:gst_nvvideoconvert_fixate_caps:<conv1> nvbuf-memory-type property is set based on SRC caps. Property config setting (if any) is overridden!!
0:00:01.371555180 63357 0x7b2508028520 WARN nvvideoconvert gstnvvideoconvert.c:1962:gst_nvvideoconvert_fixate_caps:<conv1> gpu-id property is set based on SRC caps. Property config setting (if any) is overridden!!
0:00:01.371758660 63357 0x7b2508028520 WARN nvvideoconvert gstnvvideoconvert.c:1957:gst_nvvideoconvert_fixate_caps:<conv1> nvbuf-memory-type property is set based on SRC caps. Property config setting (if any) is overridden!!
0:00:01.371767050 63357 0x7b2508028520 WARN nvvideoconvert gstnvvideoconvert.c:1962:gst_nvvideoconvert_fixate_caps:<conv1> gpu-id property is set based on SRC caps. Property config setting (if any) is overridden!!
Which in my experience leads to crossed-memory allocation error.
So if I understand correctly, on DS6.2 there is no warning due to an issue. And from DS6.3 on, the software will allocate the GPU based on caps? If so, how can I make sure that it’s using the GPU I want to set programmatically? Is there a way to set this on the caps? Why running the same software on DS6.3 will end up in a CUDA error due to memory allocation when DS6.2 does not?
If it helps, removing the custom elements from the pipeline will still reproduce the issue (my bad on that one).
DS-6.2 does not add warning logs, these logs are added in DS-6.3
This is a problem negotiated by gstreamer element. nvvideoconvert must work on the same GPU as nvstreammux.
In addition, if you need to force the GPU to be specified, you can use this environment variable, which ensures that all elements work on the same GPU.
