How can I get the arm64 driver for Tesla P4 on Jetson Nano?
Dear nvidia Jetson support,
I have connected the Tesla P4 on the Jetson Nano. lspci was able to detecte the P4.
On the other hand, “deviceQuery” on CUDA sample did not recognize it. I am wondering if that is because
the driver for P4 was not installed on that( Nano JetPack 4.2, June 7th released SD-Image ).
Can I ask you following questions?
  • Questions
    Q1. Does the JetPack 4.2 include the driver of dGPU(in this case P4) ?
    Q2. When JetPack 4.2 includes the driver for P4, can you tell me the way to activate it?
    Q3. When JetPack 4.2 does not include the arm64 P4 driver, can you kindly show me the way
    to get arm64 Tesla driver?
  • Note
    a) This is done on Jetson Nano Developer Kit and Tesla P4.
    b) The connection between the Nano and Tesla P4 is PCI express on M.2 E-Key at Nano Devkit.
    c) It would be very nice that the driver works on Xavier, too. Xavier has PCIe Slot. It is much easier to use.
lspci
00:01.0 PCI bridge: NVIDIA Corporation Device 0fae (rev a1)
00:02.0 PCI bridge: NVIDIA Corporation Device 0faf (rev a1)
01:00.0 PCI bridge: NEC Corporation Device 0031
02:00.0 PCI bridge: NEC Corporation Device 0032
03:00.0 3D controller: NVIDIA Corporation GP104GL [Tesla P4] (rev a1)
04:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
uname -r
4.9.140
deviceQuery
deviceQuery Starting...
 CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 1 CUDA Capable device(s)
Device 0: "NVIDIA Tegra X1"
  CUDA Driver Version / Runtime Version          10.0 / 10.0
  CUDA Capability Major/Minor version number:    5.3
  Total amount of global memory:                 3956 MBytes (4148494336 bytes)
  ( 1) Multiprocessors, (128) CUDA Cores/MP:     128 CUDA Cores
  GPU Max Clock rate:                            922 MHz (0.92 GHz)
  Memory Clock rate:                             13 Mhz
  Memory Bus Width:                              64-bit
  L2 Cache Size:                                 262144 bytes
  Maximum Texture Dimension Size (x,y,z)         1D=(65536), 2D=(65536, 65536), 3D=(4096, 4096, 4096)
  Maximum Layered 1D Texture Size, (num) layers  1D=(16384), 2048 layers
  Maximum Layered 2D Texture Size, (num) layers  2D=(16384, 16384), 2048 layers
  Total amount of constant memory:               65536 bytes
  Total amount of shared memory per block:       49152 bytes
  Total number of registers available per block: 32768
  Warp size:                                     32
  Maximum number of threads per multiprocessor:  2048
  Maximum number of threads per block:           1024
  Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
  Max dimension size of a grid size    (x,y,z): (2147483647, 65535, 65535)
  Maximum memory pitch:                          2147483647 bytes
  Texture alignment:                             512 bytes
  Concurrent copy and kernel execution:          Yes with 1 copy engine(s)
  Run time limit on kernels:                     Yes
  Integrated GPU sharing Host Memory:            Yes
  Support host page-locked memory mapping:       Yes
  Alignment requirement for Surfaces:            Yes
  Device has ECC support:                        Disabled
  Device supports Unified Addressing (UVA):      Yes
  Device supports Compute Preemption:            No
  Supports Cooperative Kernel Launch:            No
  Supports MultiDevice Co-op Kernel Launch:      No
  Device PCI Domain ID / Bus ID / location ID:   0 / 0 / 0
  Compute Mode:
     < Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 10.0, CUDA Runtime Version = 10.0, NumDevs = 1
Result = PASS
lsmod
Module                  Size  Used by
fuse                  111691  3
bnep                   18758  2
overlay                51662  0
nvs                    62103  0
nvgpu                1694373  18
bluedroid_pm           16059  0
ip_tables              21421  0
x_tables               38016  1 ip_tables
Can you please share ‘sudo lspci -vvvv’ output?
sudo lspci -vvv is shown below.
It seems that no kernel drivers are assigned to the Tesla P4.
The connections are Nano — PCIe Switch — Tesla P4.
If arm driver for P4 is already installed on JetPack, I will investigate the system further.
Hope, this will help!
$ sudo lspci -vvv
00:01.0 PCI bridge: NVIDIA Corporation Device 0fae (rev a1) (prog-if 00 [Normal decode])
        Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
        Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 0
        Interrupt: pin A routed to IRQ 84
        Bus: primary=00, secondary=01, subordinate=03, sec-latency=0
        I/O behind bridge: 0000f000-00000fff
        Memory behind bridge: 13000000-13ffffff
        Prefetchable memory behind bridge: 0000000020000000-0000000037ffffff
        Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
        BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
                PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
        Capabilities: [40] Subsystem: NVIDIA Corporation Device 0000
        Capabilities: [48] Power Management version 3
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
                Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
        Capabilities: [50] MSI: Enable- Count=1/2 Maskable- 64bit+
                Address: 0000000000000000  Data: 0000
        Capabilities: [60] HyperTransport: MSI Mapping Enable- Fixed-
                Mapping Address Base: 00000000fee00000
        Capabilities: [80] Express (v2) Root Port (Slot+), MSI 00
                DevCap: MaxPayload 128 bytes, PhantFunc 0
                        ExtTag+ RBE+
                DevCtl: Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported+
                        RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
                        MaxPayload 128 bytes, MaxReadReq 512 bytes
                DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
                LnkCap: Port #0, Speed 5GT/s, Width x4, ASPM L0s L1, Exit Latency L0s <512ns, L1 <4us
                        ClockPM- Surprise- LLActRep+ BwNot+ ASPMOptComp-
                LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk-
                        ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
                LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive+ BWMgmt+ ABWMgmt-
                SltCap: AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug- Surprise-
                        Slot #0, PowerLimit 0.000W; Interlock- NoCompl-
                SltCtl: Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
                        Control: AttnInd Off, PwrInd On, Power- Interlock-
                SltSta: Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet+ Interlock-
                        Changed: MRL- PresDet+ LinkState+
                RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna+ CRSVisible-
                RootCap: CRSVisible-
                RootSta: PME ReqID 0000, PMEStatus- PMEPending-
                DevCap2: Completion Timeout: Range AB, TimeoutDis+, LTR+, OBFF Not Supported ARIFwd-
                DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR+, OBFF Disabled ARIFwd-
                LnkCtl2: Target Link Speed: 2.5GT/s, EnterCompliance- SpeedDis-
                         Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
                         Compliance De-emphasis: -6dB
                LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
                         EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
        Capabilities: [100 v1] Advanced Error Reporting
                UESta:  DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
                UEMsk:  DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
                UESvrt: DLP+ SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
                CESta:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
                CEMsk:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
                AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
        Capabilities: [140 v1] L1 PM Substates
                L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
                          PortCommonModeRestoreTime=30us PortTPowerOnTime=70us
                L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-
                           T_CommonMode=30us LTR1.2_Threshold=0ns
                L1SubCtl2: T_PwrOn=70us
        Kernel driver in use: pcieport
00:02.0 PCI bridge: NVIDIA Corporation Device 0faf (rev a1) (prog-if 00 [Normal decode])
        Latency: 0
        Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
        I/O behind bridge: 00001000-00001fff
        Memory behind bridge: 14000000-140fffff
        Prefetchable memory behind bridge: 00000000fff00000-00000000000fffff
                        ExtTag+ RBE+
                LnkCap: Port #1, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <512ns, L1 <4us
                LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk+
                LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive+ BWMgmt- ABWMgmt-
                           T_CommonMode=150us LTR1.2_Threshold=294912ns
                L1SubCtl2: T_PwrOn=150us
01:00.0 PCI bridge: NEC Corporation Device 0031 (prog-if 00 [Normal decode])
        Latency: 0
        Bus: primary=01, secondary=02, subordinate=03, sec-latency=0
        Capabilities: [80] Express (v2) Upstream Port, MSI 00
                DevCap: MaxPayload 512 bytes, PhantFunc 0
                        ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ SlotPowerLimit 0.000W
                DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
                        RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+
                LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM not supported, Exit Latency L0s <64ns, L1 <1us
                        ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
                LnkCtl: ASPM Disabled; Disabled- CommClk-
                LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk- DLActive- BWMgmt- ABWMgmt-
                DevCap2: Completion Timeout: Not Supported, TimeoutDis-, LTR-, OBFF Not Supported
                DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
                LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
        Capabilities: [f8] Power Management version 3
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
                Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
        Capabilities: [100 v1] Vendor Specific Information: ID=1556 Rev=1 Len=008 <?>
        Capabilities: [200 v2] Advanced Error Reporting
                UESvrt: DLP+ SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP+ ECRC- UnsupReq- ACSViol-
                AERCap: First Error Pointer: 00, GenCap- CGenEn- ChkCap+ ChkEn-
02:00.0 PCI bridge: NEC Corporation Device 0032 (prog-if 00 [Normal decode])
        Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx+
        Latency: 0
        Interrupt: pin ? routed to IRQ 405
        Bus: primary=02, secondary=03, subordinate=03, sec-latency=0
        Capabilities: [80] Express (v2) Downstream Port (Slot+), MSI 00
                        ExtTag+ RBE+
                LnkCap: Port #1, Speed 2.5GT/s, Width x1, ASPM not supported, Exit Latency L0s <64ns, L1 <1us
                        ClockPM- Surprise+ LLActRep+ BwNot- ASPMOptComp+
                LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk- DLActive+ BWMgmt- ABWMgmt-
                        Slot #1, PowerLimit 0.000W; Interlock- NoCompl+
                        Control: AttnInd Off, PwrInd Off, Power- Interlock-
                        Changed: MRL- PresDet- LinkState+
                DevCap2: Completion Timeout: Not Supported, TimeoutDis-, LTR-, OBFF Not Supported ARIFwd+
                DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled ARIFwd-
                LnkCtl2: Target Link Speed: 2.5GT/s, EnterCompliance- SpeedDis-, Selectable De-emphasis: -6dB
        Capabilities: [e0] MSI: Enable+ Count=1/1 Maskable- 64bit+
                Address: 00000000fa827000  Data: 0000
                UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP+ ECRC- UnsupReq- ACSViol-
        Capabilities: [800 v1] Access Control Services
                ACSCap: SrcValid+ TransBlk+ ReqRedir+ CmpltRedir+ UpstreamFwd+ EgressCtrl- DirectTrans+
                ACSCtl: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
        Subsystem: NVIDIA Corporation GP104GL [Tesla P4]
        Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
        Region 0: Memory at 13000000 (32-bit, non-prefetchable) [disabled]
        Region 1: Memory at 20000000 (64-bit, prefetchable) [disabled]
        Region 3: Memory at 30000000 (64-bit, prefetchable) [disabled]
        Capabilities: [60] Power Management version 3
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
        Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
        Capabilities: [78] Express (v2) Endpoint, MSI 00
                DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s unlimited, L1 <64us
                        ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 0.000W
                LnkCap: Port #1, Speed 8GT/s, Width x16, ASPM not supported, Exit Latency L0s <512ns, L1 <4us
                        ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
                LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
                DevCap2: Completion Timeout: Range AB, TimeoutDis+, LTR+, OBFF Via message
                LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis-
        Capabilities: [100 v1] Virtual Channel
                Caps:   LPEVC=0 RefClk=100ns PATEntryBits=1
                Arb:    Fixed- WRR32- WRR64- WRR128-
                Ctrl:   ArbSelect=Fixed
                Status: InProgress-
                VC0:    Caps:   PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
                        Arb:    Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256-
                        Ctrl:   Enable+ ID=0 ArbSelect=Fixed TC/VC=ff
                        Status: NegoPending- InProgress-
        Capabilities: [250 v1] Latency Tolerance Reporting
                Max snoop latency: 0ns
                Max no snoop latency: 0ns
        Capabilities: [128 v1] Power Budgeting <?>
        Capabilities: [420 v2] Advanced Error Reporting
                UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
                AERCap: First Error Pointer: 00, GenCap- CGenEn- ChkCap- ChkEn-
        Capabilities: [600 v1] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
        Capabilities: [900 v1] #19
        Subsystem: Realtek Semiconductor Co., Ltd. RTL8111/8168 PCI Express Gigabit Ethernet controller
        Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
        Latency: 0, Cache Line Size: 64 bytes
        Interrupt: pin A routed to IRQ 406
        Region 0: I/O ports at 1000
        Region 2: Memory at 14004000 (64-bit, non-prefetchable)
        Region 4: Memory at 14000000 (64-bit, non-prefetchable)
        Capabilities: [40] Power Management version 3
                Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=375mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
        Capabilities: [50] MSI: Enable+ Count=1/1 Maskable- 64bit+
                Address: 00000000fa827000  Data: 0001
        Capabilities: [70] Express (v2) Endpoint, MSI 01
                DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s <512ns, L1 <64us
                        ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 0.000W
                        RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop-
                        MaxPayload 128 bytes, MaxReadReq 4096 bytes
                DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
                LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s unlimited, L1 <64us
                DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR+, OBFF Via message/WAKE#
        Capabilities: [b0] MSI-X: Enable- Count=4 Masked-
                Vector table: BAR=4 offset=00000000
                PBA: BAR=4 offset=00000800
        Capabilities: [100 v2] Advanced Error Reporting
                UEMsk:  DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq+ ACSViol-
        Capabilities: [140 v1] Virtual Channel
                Status: InProgress-
        Capabilities: [160 v1] Device Serial Number 00-00-00-00-00-00-00-00
        Capabilities: [170 v1] Latency Tolerance Reporting
        Capabilities: [178 v1] L1 PM Substates
                          PortCommonModeRestoreTime=150us PortTPowerOnTime=150us
                           T_CommonMode=0us LTR1.2_Threshold=294912ns
        Kernel driver in use: r8168
Officially we are not shipping any Tesla P4 GPU drivers with JetPack release. Having said that, if you have the driver available in source code form, you can compile it for aarch64 architecture and that should work. You may need to check in Tegra P4 forums for that information.
Hi, vidyas
Thank you for your quick response.
Is the situation same for the other dGPU, K80, M80, V100, Quadro P, GTX, RTX, etc?
I may be able to prepare them except for the RTX. Besides, do you have any plan to release the dGPU driver for any Jetson in the near future?
  • shino
Yes, the same situation is for other dGPU too. Currently there is no plan.
Thank you for your response.
It seems sad if no Jetson suport dGPU even though Xavier has a PCIe slot. However, I have found the following topic. It showed that your team provided dGPU in the list of verified cards.
https://devtalk.nvidia.com/default/topic/1046654/jetson-agx-xavier/jetson-xavier-pcie-add-on-cards-tested/post/5311763/#5311763
Following cards have been verified
RCS_r2UG-A2E16-A PCIe Switch
Nvidia'a dGPU
Could you tell which dGPU has been verified ?
That was to run some Nvidia’s internal diagnostic framework on dGPU (mostly to verify the PCIe interface itself) and not meant to run dGPU driver as such.
I understood the current situation.
– shino
