Now Im programming for medical image reconstruction like CT or MRI…
In gerneral C code, I can read and write raw files just using “fopen fread fwrite”.
But Is there any image read function in CUDA? like “Cuda_PGM_reader”…
Or Can I use “fopen” built in function?
How can I Image processing using CUDA? How can I write to image files…
I must be crazy because of CUDA…
best regards…
DenisR
2
You do not use CUDA to do these things, those things you just do in plain C. It is just some offloading of heavy calculations to GPU. So you do :
in C
load your data
upload data to GPU
in CUDA
run a kernel that constructs the image(s)
in C
download data from GPU
save your data to image files.
Thanx for your fast reply.
Best regard…
This is Radhika .
For one of my assignment I have to construct an image from MRI/Ultrasound raw data.
I required MRI/Ultrasound raw data for constructing an image.
If u know any details regarding this please give the information as early as possible.
Regards,
Radhika
