How can i run NVIDIA ARC-OTA in RTX 5080?
I want to set up the NVIDIA Aerial RAN Colab Over-the-Air (ARC-OTA) environment on my system, which consists of an ASUS X87-Plus motherboard, an AMD 9900X CPU, and an RTX 5080 GPU.
However, when I follow Section 4.5 of the official documentation, I encounter an error starting from the command in Step 4.5.3.5 (OAI L2 image build):
docker build . -f docker∕Dockerfile.gNB.aerial.ubuntu22 --tag oai-gnb-aerial:latest
I suspect this is because the official documentation assumes a Grace Hopper system.
Therefore, I’m wondering whether there is a supported method to build and run the ARC-OTA environment on my hardware configuration as well.
Hi @rikin.andy
Glad to know you are interested in checking ARC-OTA. Unfortunately, the HWs you are trying to use is not tested and supported for ARC-OTA.
FYI Aerial-CUDA-Accellerated-RAN is opensoure now at https://github.com/NVIDIA/aerial-cuda-accelerated-ran
Also, please register NVIDIA 6G Developer Day , you will get more info
