I am getting started with Aerial and following the instruction from : Getting Started with pyAerial - NVIDIA Docs
As per the instructions, it says " To create and launch the pyAerial container, the following are needed:
- NVIDIA Aerial CUDA-Accelerated RAN container, see instructions here.
*2) Docker installation, see instructions here.
- HPC Container Maker (HPCCM) installation"
I would appreciate clarifications against the first 1 point above:
- Is the NVIDIA Aerial CUDA-Accelerated RAN container image enough and the PyAerial can can be complied and run on CPU as well? I see the following "Note that pyAerial, similarly to Aerial cuPHY, is by default built for GPUs with compute capabilities 8.0 or 9.0, and these are also what pyAerial has been tested against. . So would like to confirm in order to try out.
I guess points 2 and 3 is pretty much straight forward, so would require clarification on point 1.
