From the 6G developer program, I didn’t found the link to download the sourcecode.
Is there anyone can tell how to get the source code?
From 6G developer program, you can navigate to NVIDIA NGC to get cuBB container by clicking “Get Aerial CUDA-Accelerated RAN” , as shown in the captured figure below.
OR please try this link: Aerial CUDA-Accelerated RAN | NVIDIA NGC
Thanks for your reply.
I have tried and get the following fail.
I used the key generated from https://org.ngc.nvidia.com/setup/api-key
[root@localhost cert]# docker login nvcr.io
Emulate Docker CLI using podman. Create /etc/containers/nodocker to quiet msg.
Username: $oauthtoken
Password:
Login Succeeded!
[root@localhost cert]# docker pull nvcr.io/nvidia/aerial/aerial-cuda-accelerated-ran:25-2-cubb
Trying to pull nvcr.io/nvidia/aerial/aerial-cuda-accelerated-ran:25-2-cubb…
Error: initializing source docker://nvcr.io/nvidia/aerial/aerial-cuda-accelerated-ran:25-2-cubb: reading manifest 25-2-cubb in nvcr.io/nvidia/aerial/aerial-cuda-accelerated-ran: errors:
denied: requested access to the resource is denied
unauthorized: authentication required
What should I do next?
I also checked another question : Cannot pull Aerial CUDA-Accelerated RAN 25-2 - #4 , My situation is same with this one.
And I also tried docker logout nvcr.io , and then logout NGC web site,
Then re login and select “aerial-ran-and-ai-radio-framework”
Then re-generate the key. And the same issue still happen.
