At present, yes, the subscription to Aerial-ran-and-ai-radio-Framework on 6G developer Programe is needed. From your screen capture, you are already a member of 6GDP. Please try regenerating the API key for accessing the aerial-ran-and-ai-radio-framework (https://org.ngc.nvidia.com/setup/api-key) then redo docker login.
I have tried multiple times on different computers. It did not work. I always got the same error as shown in the below.
inss@5G-PC2:~/software$ sudo docker login nvcr.io
Username: $oauthtoken
Password:
WARNING! Your credentials are stored unencrypted in ‘/root/.docker/config.json’.
Configure a credential helper to remove this warning. See Login Succeeded
Thanks for your reply. It still does not work. Please see the error message below.
inss@5G-PC2:~$ sudo docker login nvcr.io
Authenticating with existing credentials… [Username: $oauthtoken]
Info → To login with a different account, run ‘docker logout’ followed by ‘docker login’
Stored credentials invalid or expired
Username ($oauthtoken):
Password:
Configure a credential helper to remove this warning. See docker login | Docker Docs
Login Succeeded
