Hi Team,
I am setting up a new DGX Spark system to run NVIDIA Aerial (AI‑RAN) simulations for a proof‑of‑concept project. This is my first time configuring DGX Spark and NGC access, so I am following the official documentation.
Steps I have completed so far
Logged into the DGX Spark machine (Ubuntu-based system).
Tried verifying GPU access with:
docker run --rm --gpus all nvidia/cuda:12.2.0-base nvidia-smi→ The image was not found locally, so it failed.
Created an NGC account and generated an API key/token.
Logged into NGC using:
docker login nvcr.io Username: $oauthtoken Password: <my NGC API key>→ Docker reported “Login Succeeded”.
But
~/.docker/config.jsonremains empty (no auth token stored). -
When attempting to pull Aerial:
docker pull nvcr.io/nvidia/aerial/aerial:latestI get this error: denied: you are not authorized to access this resource
Current Issue
I created the NGC account myself, and I have not been added to any specific NVIDIA enterprise organisation or Aerial entitlement group.
This DGX Spark is new, and I want to run Aerial simulations for demonstration and testing.
It is unclear whether DGX Spark automatically includes Aerial access or if additional entitlement is required.
Request for NVIDIA Support
Could you please clarify:
Do I need to be added to any special NVIDIA Aerial entitlement group to access:
nvcr.io/nvidia/aerial/aerial ? -
Is Aerial available for DGX Spark users by default, or does an admin need to provide enterprise access?
Why does
docker login nvcr.ionot write credentials intoconfig.json? -
What are the correct steps to authenticate and pull Aerial containers on DGX Spark?
Any guidance or documentation links would be greatly appreciated.
Thank you!
