Pull aerial-cuda-accelerated-ran:25-2-cubb Fail
Hi, Aerial Team:
I want pull the aerial container and fail, could you pls give me some guidance?
I used the key generated from https://org.ngc.nvidia.com/setup/api-key
[root@localhost cert]# docker login nvcr.io
Emulate Docker CLI using podman. Create /etc/containers/nodocker to quiet msg.
Username: $oauthtoken
Password:
Login Succeeded!
[root@localhost cert]# docker pull nvcr.io/nvidia/aerial/aerial-cuda-accelerated-ran:25-2-cubb
Trying to pull nvcr.io/nvidia/aerial/aerial-cuda-accelerated-ran:25-2-cubb
Error: initializing source docker://nvcr.io/nvidia/aerial/aerial-cuda-accelerated-ran:25-2-cubb: reading manifest 25-2-cubb in nvcr.io/nvidia/aerial/aerial-cuda-accelerated-ran: errors:
denied: requested access to the resource is denied
unauthorized: authentication required
What should I do next?
Hi @zhenping.yin
ACAR (Aerial-CUDA-Accellerated-RAN) 25-3 is opensource now. It doesn’t need membership to pull the SDK. Please check the info via GitHub - NVIDIA/aerial-cuda-accelerated-ran: An SDK (Software Development Kit) for building commercial-grade, AI-native, 3GPP, and O-RAN compliant 5G/6G gNB software on NVIDIA-accelerated computing platforms.
