Dear NVIDIA Team,
I am attempting to pull the following container image from NGC in order to run LLM inference on a MIG-enabled GH200 system. I am following Aerial documentation:
sudo docker pull nvcr.io/miicz8azigqf/fix_mid_ans_tmo_async_rag_gh200_llama3-70b-int4_with_engine:0.10.0
I am a member of the aerial-ran-and-ai-radio-framework organization and have successfully authenticated to NGC using my Docker credentials ($oauthtoken).
However, I am receiving the following error:
Error response from daemon: pull access denied for nvcr.io/miicz8azigqf/fix_mid_ans_tmo_async_rag_gh200_llama3-70b-int4_with_engine, repository does not exist or may require 'docker login': denied: requested access to the resource is denied
Could you please clarify:
Whether this image is publicly accessible?
If not, what is the procedure to request access?
Thank you for your support.
Best regards,
Hyejung Hwang
