Pull access denied for docker
I try login nvcr.io with my NGC key from org.ngc.nvidia.com/setup/api-key
This shown that:
WARNING! Using --password via the CLI is insecure. Use --password-stdin.
WARNING! Your password will be stored unencrypted in /home/tungcao/.docker/config.json.
Configure a credential helper to remove this warning. See
https://docs.docker.com/engine/reference/commandline/login/#credentials-store
Login Succeeded
But when i try:
 docker pull nvcr.io/metropolis/via-dp/via-engine:2.0-dp
Error response from daemon: pull access denied for nvcr.io/metropolis/via-dp/via-engine, repository does not exist or may require 'docker login': denied: requested access to the resource is denied
Thank you
You mean you run the docker login nvcr.io -u '$oauthtoken' -p <NGC_API_KEY> successfully, but when you run the docker pull command, it reports the pull access denied error?
Yes, that’s correct. Can you help me?
Maybe you’re using the wrong type of key. Could you refer to this docker-error-error-response-from-daemon-unauthorized and see if that can fix your issue?
I get my NGC key from org.ngc.nvidia.com/setup/api-key here, is correct?
Yes. That’s correct. We’ll investigate internally why you got the key correctly but still reported an pull access denied error.
Hi @tung.nguyen3 , have you joined our via-dp team like below?
If not, you can apply from the following page first.
https://developer.nvidia.com/ai-blueprint-for-video-search-and-summarization-early-access/join
I’m experiencing the same error.
In my subscriptions section I see: NVIDIA VSS Early Access
can login to the nvcr
$ sudo docker login nvcr.io
Authenticating with existing credentials...
Login Succeeded
but can not pull the image
$ sudo docker pull nvcr.io/metropolis/via-dp/via-engine:2.0-dp
Hi @hadhoryth , could you check my last comment to see if your via-dp group application was successful?
@yuweiw I do have access to the blueprint but can not see where I can join the metropolis/via-dp team
And in my subscriptions
You are trying to pull VIA, which is the previous developer program (You have access to VSS). When you go into the ‘Member area’, please refer to the documentation there for pulling the blueprint helm chart.
