ubuntu@ip-172-31-28-24:~$ docker login nvcr.io
Authenticating with existing credentials…
WARNING! Your password will be stored unencrypted in /home/ubuntu/.docker/config.json.
Configure a credential helper to remove this warning. See
Login Succeeded
ubuntu@ip-172-xx:~$ docker pull nvcr.io/nvstaging/omniverse-replicator:xx
Error response from daemon: pull access denied for nvcr.io/nvstaging/omniverse-replicator, repository does not exist or may require ‘docker login’: denied: requested access to the resource is denied
ubuntu@ip-172-xx:~$
I’m trying to follow this : https://docs.omniverse.nvidia.com/prod_extensions/prod_extensions/ext_replicator/container_setup.html#headless-container
