Hi NVIDIA,
Our organization is a NVAIE member. Before I could successfully push the image to our private registry.
However, now I cannot pull or push the image from our private registry by ngc cli tool that I have tried many times including re-generating the new personal API key with all options with the ngc config set.
I can pull the public docker image such as Triton docker image to make sure that my docker login nvcr.io can work fine.
Could you give me some suggestions?
Here is my partial information on Terminal.
$ docker login nvcr.io
Authenticating with existing credentials...
WARNING! Your password will be stored unencrypted in /home/chieh/.docker/config.json.
Configure a credential helper to remove this warning. See
https://docs.docker.com/engine/reference/commandline/login/#credentials-store
$ ngc config current
| key | value | source |
| apikey | ***************************************************** | user settings |
| format_type | ascii | user settings |
| org | z1gssr2t055u | user settings |
| team | metaaivi | user settings |
$ docker pull nvcr.io/z1gssr2t055u/meta-aivi:(my tag name)
Error response from daemon: pull access denied for nvcr.io/z1gssr2t055u/meta-aivi, repository does not exist or may require 'docker login': denied: requested access to the resource is denied
Thank you.
