Unauthorized:authetication required
I am unable to pull the NIM models through docker. Upon trying to pull the docker model with:
{USER REDACTED}:~$ docker pull $IMG_NAME
Error response from daemon: Head “https://nvcr.io/v2/nim/meta/llama3-70b-instruct/manifests/1.0.0”: unauthorized: authentication required
I already received successful login verification by using:
{USER REDACTED}:~$ echo $NGC_API_KEY | docker login nvcr.io --username ‘$oauthtoken’ --password-stdin
WARNING! Your password will be stored unencrypted in {redacted}
Configure a credential helper to remove this warning. See
docker login | Docker Docs
Login Succeeded
I generated a new API key and it is working now. However, it is identifying my GPU as not-available. I have reinstalled all the drivers and pre-installation requirements. RTX4090.
I’m having the same issue. I’ve tried generating a new API key but I still see the authentication error.
@steve157 I believe it’s the personal key you can create here: https://org.ngc.nvidia.com/setup/personal-keys. Let me know if you are successful. I am authenticating and pulling the models now but getting an error about non-free GPU. Running RTX4090.
