Failed to pull the image 25-2-cubb
I tried to pull the image 25-2-cubb using the command sudo docker pull nvcr.io/nvidia/aerial/aerial-cuda-accelerated-ran:25-2-cubb , but it failed.
I also noticed that there is no 25-2 image listed on the website NVIDIA NGC .
Does it require special permission or a paid subscription?
Hi @justin.jy.huang ,
No special permission is required for 25-2 image. Have you tried first logging into the system with
sudo docker login nvcr.io
using your credentials and then attempted to pull the image?
I tried the same and I do not see any issues.
Thank you.
Yup, as the image shows above, I could log into the system successfully.
I also tried to pull the image 25-1 using sudo docker pull nvcr.io/nvidia/aerial/aerial-cuda-accelerated-ran:25-1-cubb according to How to proceed with installation of the aerial sdk, even with a access key ,we are not getting access to pull the sdk - #14 , but that failed as well.
Can you help me check the issue again?
Did you receive this invitation and accept it? You may need to recreate a token after this.
After create a NVIDIA Cloud Account, I can pull the image 25-2 now. Thank you for your help. :)
