I am using the deepstream sdk in my jetson nano for inference and getting the data from video but I am finding it difficult how can I send this data to my backend which is a spring boot app to save it in a database. Please be kind enough to give any suggestions or solutions as soon as possible as I am short of time. Thanks in advance !
Hey, can you share your setup with us?
Sure I am planning on using the existing occupancy analytics project which was provided by the nvidia.
The config file is
Copyright (c) 2018-2020, NVIDIA CORPORATION. All rights reserved.
Permission is hereby granted, free of charge, to any person obtaining a
copy of this software and associated documentation files (the “Software”),
to deal in the Software without restriction, including without limitation
the rights to use, copy, modify, merge, publish, distribute, sublicense,
and/or sell copies of the Software, and to permit persons to whom the
Software is furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in
all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED “AS IS”, WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
DEALINGS IN THE SOFTWARE.
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=1
rows=1
columns=1
width=1280
height=720
gpu-id=0
#(0): nvbuf-mem-default - Default memory allocated, specific to particular platform
#(1): nvbuf-mem-cuda-pinned - Allocate Pinned/Host cuda memory, applicable for Tesla
#(2): nvbuf-mem-cuda-device - Allocate Device cuda memory, applicable for Tesla
#(3): nvbuf-mem-cuda-unified - Allocate Unified cuda memory, applicable for Tesla
#(4): nvbuf-mem-surface-array - Allocate Surface Array memory, applicable for Jetson
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI
type=3
uri=file:///home/ubuntu/Downloads/new1.mp4
num-sources=1
gpu-id=0
nvbuf-memory-type=0
[source1]
enable=0
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=3
uri=file:///opt/nvidia/deepstream/deepstream-5.0/samples/streams/sample_1080p_h264.mp4
num-sources=1
gpu-id=0
nvbuf-memory-type=0
smart record specific fields, valid only for source type=4
0 = disable, 1 = through cloud events, 2 = through cloud + local events
smart-record=2
0 = mp4, 1 = mkv
#smart-rec-container=0
smart-rec-start-time=1
smart-rec-file-prefix=smart_record
#smart-rec-dir-path=/home/monika/record
video cache size in seconds
smart-rec-video-cache=10
[sink0]
enable=1
type=2
#1=mp4 2=mkv./bin/kafka-topics --create --bootstrap-server localhost:9092
#–replication-factor 1 --partitions 1 --topic users
container=1
#1=h264 2=h265
codec=1
encoder type 0=Hardware 1=Software
enc-type=0
sync=0
#iframeinterval=10
bitrate=100000
#H264 Profile - 0=Baseline 2=Main 4=High
#H265 Profile - 0=Main 1=Main10
profile=0
output-file=resnet.mp4
source-id=0
[sink1]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=UDPSink 5=nvoverlaysink 6=MsgConvBroker
type=6
msg-conv-config=dstest5_msgconv_sample_config.txt
#(0): PAYLOAD_DEEPSTREAM - Deepstream schema payload
#(1): PAYLOAD_DEEPSTREAM_MINIMAL - Deepstream schema payload minimal
#(256): PAYLOAD_RESERVED - Reserved type
#(257): PAYLOAD_CUSTOM - Custom schema payload
msg-conv-payload-type=0
msg-broker-proto-lib=/opt/nvidia/deepstream/deepstream-5.1/lib/libnvds_kafka_proto.so
#Provide your msg-broker-conn-str here
msg-broker-conn-str=localhost;9092;quickstart-events
#topic=
#Optional:
#msg-broker-config=../../deepstream-test4/cfg_kafka.txt
[sink2]
enable=1
type=1
#1=mp4 2=mkv
container=1
#1=h264 2=h265 3=mpeg4
only SW mpeg4 is supported right now.
codec=3
sync=1
bitrate=2000000
output-file=out.mp4
source-id=0
sink type = 6 by default creates msg converter + broker.
To use multiple brokers use this group for converter and use
sink type = 6 with disable-msgconv = 1
[message-converter]
enable=0
Name of library having custom implementation.
#msg-conv-msg2p-lib=
Id of component in case only selected message to parse.
#msg-conv-comp-id=
Configure this group to enable cloud message consumer.
[message-consumer0]
enable=0
proto-lib=/opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_kafka_proto.so
#config-file=
subscribe-topic-list=quickstart-events
Use this option if message has sensor name as id instead of index (0,1,2 etc.).
sensor-list-file=dstest5_msgconv_sample_config.txt
[osd]
enable=1
gpu-id=0
border-width=1
text-size=10
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Arial
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=0
batch-size=1
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
Set muxer output width and height
width=1920
height=1080
#enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
If set to TRUE, system timestamp will be attached as ntp timestamp
If set to FALSE, ntp timestamp from rtspsrc, if available, will be attached
attach-sys-ts-as-ntp=1
[primary-gie]
enable=1
gpu-id=0
batch-size=1
0=FP32, 1=INT8, 2=FP16 mode
bbox-border-color0=1;0;0;1
#bbox-border-color1=0;1;1;1
#bbox-border-color2=0;1;1;1
#bbox-border-color3=0;1;0;1
nvbuf-memory-type=0
interval=0
gie-unique-id=1
model-engine-file=peoplenet/resnet34_peoplenet_pruned.etlt_b1_gpu0_int8.engine
labelfile-path=peoplenet/labels.txt
config-file=config_infer_primary_peoplenet.txt
#infer-raw-output-dir=../../../../../samples/primary_detector_raw_output/
[tracker]
enable=1
tracker-width=640
tracker-height=288
ll-lib-file=/opt/nvidia/deepstream/deepstream-5.1/lib/libnvds_nvdcf.so
#ll-config-file required for DCF/IOU only
ll-config-file=tracker_config.yml
#ll-config-file=iou_config.txt
gpu-id=0
#enable-batch-process applicable to DCF only
enable-batch-process=0
[nvds-analytics]
enable=1
config-file=config_nvdsanalytics.txt
[tests]
file-loop=0
The nvdsanalytics config file
Copyright (c) 2020, NVIDIA CORPORATION. All rights reserved.
The values in the config file are overridden by values set through GObject
properties.
[property]
enable=1
#Width height used for configuration to which below configs are configured
config-width=1920
config-height=1080
#osd-mode 0: Dont display any lines, rois and text
1: Display only lines, rois and static text i.e. labels
2: Display all info from 1 plus information about counts
osd-mode=2
set OSD font size that has to be displayed
display-font-size=12
Per stream configuration
[roi-filtering-stream-0]
enable or disable following feature
enable=1
#ROI to filter select objects, and remove from meta data
roi-RF=0;0;900;0;900;900;0;900
inverse-roi=0
class-id=0
[roi-filtering-stream-1]
enable=0
roi-RF=295;643;579;634;642;913;56;828
remove objects in the ROI
inverse-roi=0
class-id=0
[overcrowding-stream-0]
enable=0
roi-OC=0;0;900;0;900;900;0;900
#no of objects that will trigger OC
object-threshold=1
class-id=0
[line-crossing-stream-0]
enable=1
#Label;direction;lc
line-crossing-Exit=900;1000;850;900;300;1000;1350;800;
line-crossing-Entry=750;670;800;750;300;850;1350;650
#line_color=0.75;0.25;0;1
class-id=0
#extended when 0- only counts crossing on the configured Line
1- assumes extended Line crossing counts all the crossing
extended=0
#LC modes supported:
#loose : counts all crossing without strong adherence to direction
#balanced: Strict direction adherence expected compared to mode=loose
#strict : Strict direction adherence expected compared to mode=balanced
mode=balanced
[line-crossing-stream-1]
enable=1
#Label;direction;lc
class-id=0
extended=1
mode=balanced
[direction-detection-stream-0]
enable=0
#Label;direction;
direction-South=284;840;360;662;
direction-North=1106;622;1312;701;
class-id=0
Actually, I mean following info. Also please share the whole file or make the post code use markdown format if you are sharing some source code…
• DeepStream Version
• TensorRT Version
Jetson Nano 4GB
Deepstream version : 5.1
Jetpack version : 4.5.1
TensorRT version : 7.1.3
I am creating a crowd counting app which detects the crowd count in live video feed and sends it back to the backend server to save it in a database. The edge device which detects the crowd count is jetson nano device. I installed the deepstream sdk to get the people count within a specific area but I am finding it difficult to send the data to the cloud using the message brokers such kafka.
Could you follow this to share the config files.
What’s the spring boot app.
Also have you checked Gst-nvmsgbroker — DeepStream 6.3 Release documentation and Gst-nvmsgconv — DeepStream 6.3 Release documentation
