• Hardware Platform (Jetson / GPU) GPU RTX 3060
• DeepStream Version 6.1
• NVIDIA GPU Driver Version (valid for GPU only) version 515
here config ds_transfer_learning_app_example.txt
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=1
rows=1
columns=1
width=1280
height=720
gpu-id=0
#(0): nvbuf-mem-default - Default memory allocated, specific to particular platform
#(1): nvbuf-mem-cuda-pinned - Allocate Pinned/Host cuda memory applicable for Tesla
#(2): nvbuf-mem-cuda-device - Allocate Device cuda memory applicable for Tesla
#(3): nvbuf-mem-cuda-unified - Allocate Unified cuda memory applicable for Tesla
#(4): nvbuf-mem-surface-array - Allocate Surface Array memory, applicable for Jetson
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=3
uri=file://…/…/…/…/…/samples/streams/sample_1080p_h264.mp4
num-sources=1
#drop-frame-interval=2
gpu-id=0
(0): memtype_device - Memory type Device
(1): memtype_pinned - Memory type Host Pinned
(2): memtype_unified - Memory type Unified
cudadec-memtype=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=2
sync=1
source-id=0
gpu-id=0
nvbuf-memory-type=0
[sink1]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=UDPSink 5=nvoverlaysink 6=MsgConvBroker
type=6
msg-conv-config=dstest5_msgconv_sample_config.txt
#(0): PAYLOAD_DEEPSTREAM - Deepstream schema payload
#(1): PAYLOAD_DEEPSTREAM_MINIMAL - Deepstream schema payload minimal
#(256): PAYLOAD_RESERVED - Reserved type
#(257): PAYLOAD_CUSTOM - Custom schema payload
msg-conv-payload-type=0
msg-broker-proto-lib=/opt/nvidia/deepstream/deepstream-6.1/lib/libnvds_kafka_proto.so
msg-broker-conn-str=localhost;9092;test1
topic=test1
[message-converter]
enable=0
msg-conv-payload-type=1
#Name of library having custom implementation.
msg-conv-msg2p-lib=/opt/nvidia/deepstream/deepstream-6.1/lib/libnvds_msgconv.so
#Id of component in case only selected message to parse.
msg-conv-comp-id=0
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=0
batch-size=1
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
Set muxer output width and height
width=1920
height=1080
##Enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
If set to TRUE, system timestamp will be attached as ntp timestamp
If set to FALSE, ntp timestamp from rtspsrc, if available, will be attached
attach-sys-ts-as-ntp=1
config-file property is mandatory for any gie section.
Other properties are optional and if set will override the properties set in
the infer config file.
[primary-gie]
enable=1
gpu-id=0
model-engine-file=…/…/…/…/…/samples/models/Primary_Detector/resnet10.caffemodel_b4_gpu0_int8.engine
batch-size=4
uncomment down line for preprocess
input-tensor-meta=0
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=0
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary_ds_transfer_learning.txt
[pre-process]
enable=0
config-file=config_preprocess.txt
[nvds-analytics]
enable=1
config-file=config_nvdsanalytics.txt
[tracker]
enable=1
For NvDCF and DeepSORT tracker, tracker-width and tracker-height must be a multiple of 32, respectively
tracker-width=640
tracker-height=384
ll-lib-file=/opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
ll-config-file required to set different tracker types
ll-config-file=…/…/…/…/…/samples/configs/deepstream-app/config_tracker_IOU.yml
ll-config-file=…/…/…/…/…/samples/configs/deepstream-app/config_tracker_NvDCF_perf.yml
ll-config-file=…/…/…/…/…/samples/configs/deepstream-app/config_tracker_NvDCF_accuracy.yml
ll-config-file=…/…/…/…/…/samples/configs/deepstream-app/config_tracker_DeepSORT.yml
gpu-id=0
enable-batch-process=1
enable-past-frame=1
display-tracking-id=1
[tests]
file-loop=0
[img-save]
enable=1
output-folder-path=./output
save-img-cropped-obj=1
save-img-full-frame=1
frame-to-skip-rules-path=capture_time_rules.csv
second-to-skip-interval=1
min-confidence=0.9
max-confidence=1.0
min-box-width=5
min-box-height=5
