no any logs ,i use GST_DEBUG=3 python3 main.py start my code,no any error logs
root@ps:/tmp/data/api# GST_DEBUG=3 python3 main.py
2024-11-20 06:37:00.265 | INFO | component.onnx_to_trt:process_onnx:77 - The engine file '/models/engine/yolov8x-trt-fp16-netsize-640-batch-16.engine' already exists and will be reused. Use --force to rebuild.
2024-11-20 06:37:00.272 | INFO | component.onnx_to_trt:update_config_file:127 - PGIE Configuration file 'config/config_pgie_yolo_det.yaml' updated.
2024-11-20 06:37:00.275 | INFO | component.pipeline:create_rtsp_server:36 - ***DeepStream: Launched RTSP Streaming at rtsp://localhost:8554//live***
2024-11-20 06:37:00.286 | INFO | component.pipeline:create_pipeline_multiuri:161 - Creating Pipeline
2024-11-20 06:37:00.286 | INFO | component.pipeline:create_pipeline_multiuri:167 - Creating Source
2024-11-20 06:37:00.343 | INFO | component.pipeline:create_pipeline_multiuri:313 - Adding elements to Pipeline
2024-11-20 06:37:00.343 | INFO | component.pipeline:create_pipeline_multiuri:337 - Linking elements in the Pipeline
2024-11-20 06:37:00.350 | INFO | __main__:main:61 - Starting pipeline
Failed to query video capabilities: Invalid argument
Civetweb version: v1.16
Server running at port: 9999
0:00:00.414270888 6208 0x560d0daea9d0 INFO nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2092> [UID = 1]: deserialized trt engine from :/models/engine/yolov8x-trt-fp16-netsize-640-batch-16.engine
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:327 [FullDims Engine Info]: layers num: 5
0 INPUT kFLOAT images 3x640x640 min: 1x3x640x640 opt: 16x3x640x640 Max: 16x3x640x640
1 OUTPUT kINT32 num_dets 1 min: 0 opt: 0 Max: 0
2 OUTPUT kFLOAT det_boxes 100x4 min: 0 opt: 0 Max: 0
3 OUTPUT kFLOAT det_scores 100 min: 0 opt: 0 Max: 0
4 OUTPUT kINT32 det_classes 100 min: 0 opt: 0 Max: 0
0:00:00.414337971 6208 0x560d0daea9d0 INFO nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2195> [UID = 1]: Use deserialized engine model: /models/engine/yolov8x-trt-fp16-netsize-640-batch-16.engine
0:00:00.418414483 6208 0x560d0daea9d0 INFO nvinfer gstnvinfer_impl.cpp:343:notifyLoadModelStatus:<primary-inference> [UID 1]: Load new model:config/config_pgie_yolo_det.yaml sucessfully
2024-11-20 06:37:00.697 | INFO | __main__:main:66 - Starting loop
**PERF: {'stream0': 0.0, 'stream1': 0.0, 'stream2': 0.0, 'stream3': 0.0, 'stream4': 0.0, 'stream5': 0.0, 'stream6': 0.0, 'stream7': 0.0, 'stream8': 0.0, 'stream9': 0.0, 'stream10': 0.0, 'stream11': 0.0, 'stream12': 0.0, 'stream13': 0.0, 'stream14': 0.0, 'stream15': 0.0, 'stream16': 0.0, 'stream17': 0.0, 'stream18': 0.0, 'stream19': 0.0, 'stream20': 0.0, 'stream21': 0.0, 'stream22': 0.0, 'stream23': 0.0, 'stream24': 0.0, 'stream25': 0.0, 'stream26': 0.0, 'stream27': 0.0, 'stream28': 0.0, 'stream29': 0.0}
uri:/api/v1/stream/add
method:POST
Warning: gst-stream-error-quark: No decoder available for type 'audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)2, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)119056e500, rate=(int)48000, channels=(int)2'. (6): ../gst/playback/gsturidecodebin.c(960): unknown_type_cb (): /GstPipeline:pipeline0/GstDsNvMultiUriBin:multi-uri/GstBin:multi-uri_creator/GstDsNvUriSrcBin:dsnvurisrcbin0/GstURIDecodeBin:nvurisrc_bin_src_elem
mimetype is video/x-raw
**PERF: {'stream0': 33.35, 'stream1': 0.0, 'stream2': 0.0, 'stream3': 0.0, 'stream4': 0.0, 'stream5': 0.0, 'stream6': 0.0, 'stream7': 0.0, 'stream8': 0.0, 'stream9': 0.0, 'stream10': 0.0, 'stream11': 0.0, 'stream12': 0.0, 'stream13': 0.0, 'stream14': 0.0, 'stream15': 0.0, 'stream16': 0.0, 'stream17': 0.0, 'stream18': 0.0, 'stream19': 0.0, 'stream20': 0.0, 'stream21': 0.0, 'stream22': 0.0, 'stream23': 0.0, 'stream24': 0.0, 'stream25': 0.0, 'stream26': 0.0, 'stream27': 0.0, 'stream28': 0.0, 'stream29': 0.0}
