Hi, everyone!
I’m learning to write program in CUDA. However, the first time i ran the hello_world.cu with CMake , something went wrong… I 've searched on the internet, while still cannot find an effective solution. Moreover, when i complied a libtorch program in C++, i encountered the same problem.
cmake version 3.27.7, Cuda compilation tools, release 11.5, V11.5.50 and i ran the program on remote server via VSCode.
What should I do?
Many thanks!
CMake Error at /media/data3/xxxx/cmake/share/cmake-3.27/Modules/CMakeDetermineCompilerId.cmake:753 (message):
Compiling the CUDA compiler identification source file
"CMakeCUDACompilerId.cu" failed.
Compiler: /usr/local/cuda-11.5/bin/nvcc
Build flags:
Id flags: --keep;--keep-dir;tmp -v
The output was:
1
#$ _NVVM_BRANCH_=nvvm
#$ _SPACE_=
#$ _CUDART_=cudart
#$ _HERE_=/usr/local/cuda-11.5/bin
#$ _THERE_=/usr/local/cuda-11.5/bin
#$ _TARGET_SIZE_=
#$ _TARGET_DIR_=
#$ _TARGET_DIR_=targets/x86_64-linux
#$ TOP=/usr/local/cuda-11.5/bin/..
#$ NVVMIR_LIBRARY_DIR=/usr/local/cuda-11.5/bin/../nvvm/libdevice
#$ LD_LIBRARY_PATH=/usr/local/cuda-11.5/bin/../lib:/usr/local/cuda/lib64:
PATH=/usr/local/cuda-11.5/bin/../nvvm/bin:/usr/local/cuda-11.5/bin:/media/data3/xxxx/cmake/bin:/media/data3/xxxx/miniconda3/bin:/media/data3/xxxx/miniconda3/condabin:/usr/local/cuda/bin:/home/xxxx/.vscode-server/bin/f1b07bd25dfad64b0167beb15359ae573aecd2cc/bin/remote-cli:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
#$ INCLUDES="-I/usr/local/cuda-11.5/bin/../targets/x86_64-linux/include"
#$ LIBRARIES=
"-L/usr/local/cuda-11.5/bin/../targets/x86_64-linux/lib/stubs"
"-L/usr/local/cuda-11.5/bin/../targets/x86_64-linux/lib"
#$ CUDAFE_FLAGS=
#$ PTXAS_FLAGS=
#$ rm tmp/a_dlink.reg.c
#$ gcc -D__CUDA_ARCH__=520 -D__CUDA_ARCH_LIST__=520 -E -x c++
-DCUDA_DOUBLE_MATH_FUNCTIONS -D__CUDACC__ -D__NVCC__
-D__CUDACC_VER_MAJOR__=11 -D__CUDACC_VER_MINOR__=5
-D__CUDACC_VER_BUILD__=50 -D__CUDA_API_VER_MAJOR__=11
-D__CUDA_API_VER_MINOR__=5 -D__NVCC_DIAG_PRAGMA_SUPPORT__=1 -include
"cuda_runtime.h" -m64 "CMakeCUDACompilerId.cu" -o
"tmp/CMakeCUDACompilerId.cpp1.ii"
#$ cicc --c++17 --gnu_version=110300 --display_error_number
--orig_src_file_name "CMakeCUDACompilerId.cu" --orig_src_path_name
"/media/data3/xxxx/model_deployment/cuda/CMakeFiles/3.27.7/CompilerIdCUDA/CMakeCUDACompilerId.cu"
--allow_managed -arch compute_52 -m64 --no-version-ident -ftz=0 -prec_div=1
-prec_sqrt=1 -fmad=1 --include_file_name "CMakeCUDACompilerId.fatbin.c"
-tused --gen_module_id_file --module_id_file_name
"tmp/CMakeCUDACompilerId.module_id" --gen_c_file_name
"tmp/CMakeCUDACompilerId.cudafe1.c" --stub_file_name
"tmp/CMakeCUDACompilerId.cudafe1.stub.c" --gen_device_file_name
"tmp/CMakeCUDACompilerId.cudafe1.gpu" "tmp/CMakeCUDACompilerId.cpp1.ii" -o
"tmp/CMakeCUDACompilerId.ptx"
/usr/include/stdio.h(189): error: attribute "__malloc__" does not take
arguments
/usr/include/stdio.h(201): error: attribute "__malloc__" does not take
arguments
/usr/include/stdio.h(223): error: attribute "__malloc__" does not take
arguments
/usr/include/stdio.h(260): error: attribute "__malloc__" does not take
arguments
/usr/include/stdio.h(285): error: attribute "__malloc__" does not take
arguments
/usr/include/stdio.h(294): error: attribute "__malloc__" does not take
arguments
/usr/include/stdio.h(303): error: attribute "__malloc__" does not take
arguments
/usr/include/stdio.h(309): error: attribute "__malloc__" does not take
arguments
/usr/include/stdio.h(315): error: attribute "__malloc__" does not take
arguments
/usr/include/stdio.h(830): error: attribute "__malloc__" does not take
arguments
/usr/include/stdlib.h(566): error: attribute "__malloc__" does not take
arguments
/usr/include/stdlib.h(570): error: attribute "__malloc__" does not take
arguments
/usr/include/stdlib.h(799): error: attribute "__malloc__" does not take
arguments
13 errors detected in the compilation of "CMakeCUDACompilerId.cu".
# --error 0x1 --
Call Stack (most recent call first):
/media/data3/xxxx/cmake/share/cmake-3.27/Modules/CMakeDetermineCompilerId.cmake:8 (CMAKE_DETERMINE_COMPILER_ID_BUILD)
/media/data3/xxxx/cmake/share/cmake-3.27/Modules/CMakeDetermineCompilerId.cmake:53 (__determine_compiler_id_test)
/media/data3/xxxx/cmake/share/cmake-3.27/Modules/CMakeDetermineCUDACompiler.cmake:307 (CMAKE_DETERMINE_COMPILER_ID)
CMakeLists.txt:4 (enable_language)
