CMake CUDA project compilation - nvlink fatal : Could not open input file '/usr/lib/libdl.a'
Hi there,
I’m currently compiling my CUDA project with CMake 3.23.0. However, I’m experiencing an error that haven’t seen before. This is my CMakeLists.txt:
cmake_minimum_required(VERSION 3.16 FATAL_ERROR)
project(gpuvmem LANGUAGES C CXX CUDA)
set(CMAKE_MODULE_PATH ${CMAKE_SOURCE_DIR}/cmake)
find_package(Boost REQUIRED)
find_package(CFITSIO REQUIRED)
find_package(CUDAToolkit REQUIRED)
set(CASACORE_MAKE_REQUIRED_EXTERNALS_OPTIONAL TRUE)
find_package(Casacore REQUIRED COMPONENTS casa ms tables measures)
option(MEMORY_DEBUG "This sets the GDB debug for CUDA code")
option(USE_FAST_MATH "This option accelerate CUDA math functions decreasing precision")
if(Boost_FOUND)
  add_executable(gpuvmem ${CMAKE_CURRENT_SOURCE_DIR}/src/main.cu)
  # Search the compute capability of the first GPU and add CUDA specific FLAGS
  include(${CMAKE_CURRENT_SOURCE_DIR}/cuda_check.cmake)
  file(GLOB SOURCE_FILES ${CMAKE_CURRENT_SOURCE_DIR}/src/*.cu)
  target_sources(gpuvmem PRIVATE ${SOURCE_FILES})
  target_compile_features(gpuvmem PUBLIC cxx_std_11)
  if(PREFIX)
    set(BINARY_DIR ${PREFIX})
    set_target_properties(gpuvmem
        PROPERTIES
        RUNTIME_OUTPUT_DIRECTORY ${BINARY_DIR}
  else()
    set(BINARY_DIR ${CMAKE_CURRENT_SOURCE_DIR}/bin)
        PROPERTIES
  endif()
  message(NOTICE "We are currently using the latest casacore stable version >=v3.2.1")
  message(NOTICE "If one these versions are not installed in your computer, please make sure to install it")
  message(NOTICE "For more information please read the README.md file")
  target_include_directories(gpuvmem PUBLIC
  ${CASACORE_INCLUDE_DIRS}
  ${CFITSIO_INCLUDE_DIR}
  ${CMAKE_CURRENT_SOURCE_DIR}/include
  ${CMAKE_CURRENT_SOURCE_DIR}/include/classes
  ${Boost_INCLUDE_DIRS}
  ${CUDA_TOOLKIT_ROOT_DIR}/samples/common/inc
  ${CUDAToolkit_INCLUDE_DIRS}
  get_target_property(TEMP gpuvmem COMPILE_FLAGS)
  if(TEMP STREQUAL "TEMP-NOTFOUND")
    set(TEMP "") # Set to empty string
  else()
    set(TEMP "${TEMP} ") # A space to cleanly separate from existing content
  endif()
  if(MEMORY_DEBUG)
    message(NOTICE "MEMORY DEBUG IS ON")
    set(COMPFLAGS "-g -G -D_FORCE_INLINES -w")
    set(TEMP "${TEMP}${COMPFLAGS}" )
    set_target_properties(gpuvmem PROPERTIES COMPILE_FLAGS ${TEMP} CUDA_SEPARABLE_COMPILATION ON CUDA_STANDARD 11)
    set(CMAKE_CUDA_FLAGS "${CMAKE_CUDA_FLAGS} -Xcompiler -fopenmp ${CUDA_NVCC_ARCH_FLAGS}")
  else()
    message(NOTICE "MEMORY DEBUG IS OFF")
    if(USE_FAST_MATH)
      message(NOTICE "USING FAST_MATH")
      set(COMPFLAGS "-D_FORCE_INLINES -w --use_fast_math -O3")
      set(CMAKE_CUDA_FLAGS "${CMAKE_CUDA_FLAGS} -Xptxas -O3 -Xcompiler -fopenmp ${CUDA_NVCC_ARCH_FLAGS}")
    else()
      set(COMPFLAGS "-D_FORCE_INLINES -w -O3")
    endif()
  endif()
  set(ALL_CUDA_LIBRARIES
    ${CUDA_cuda_LIBRARY}
    ${CUDA_cudart_LIBRARY}
    ${CUDA_cufft_LIBRARY}
  set(ALL_LIBRARIES
  	${CASACORE_LIBRARIES}
  	${CFITSIO_LIBRARY}
  	${Boost_LIBRARIES}
  target_link_libraries(gpuvmem m stdc++ gomp ${ALL_CUDA_LIBRARIES} ${ALL_LIBRARIES})
  # Adding install target
  install(TARGETS gpuvmem DESTINATION bin)
  # Tests - Tests all the testing datasets
  enable_testing()
  set(TEST_DIRECTORY ${CMAKE_CURRENT_SOURCE_DIR}/tests)
  add_test(antennae bash ${TEST_DIRECTORY}/antennae/test.sh ${BINARY_DIR}/gpuvmem ${TEST_DIRECTORY}/antennae)
  add_test(co65 bash ${TEST_DIRECTORY}/co65/test.sh ${BINARY_DIR}/gpuvmem ${TEST_DIRECTORY}/co65)
  add_test(freq78 bash ${TEST_DIRECTORY}/FREQ78/test.sh ${BINARY_DIR}/gpuvmem ${TEST_DIRECTORY}/FREQ78)
  add_test(m87 bash ${TEST_DIRECTORY}/M87/test.sh ${BINARY_DIR}/gpuvmem ${TEST_DIRECTORY}/M87)
  add_test(selfcalband9 bash ${TEST_DIRECTORY}/selfcalband9/test.sh ${BINARY_DIR}/gpuvmem ${TEST_DIRECTORY}/selfcalband9)
else()
 message(NOTICE Boost is not installed in your system. Please make sure Boost is installed before compiling.)
endif()
When I run cmake it works. The code compiles but at linking time it says: nvlink fatal : Could not open input file '/usr/lib/libdl.a'
Anyone have experienced this before? Also, if you have any comments about on how to write a better CMakeLists file just let me know :).
nvcc --version
Copyright (c) 2005-2022 NVIDIA Corporation
Built on Thu_Feb_10_18:23:41_PST_2022
Cuda compilation tools, release 11.6, V11.6.112
Build cuda_11.6.r11.6/compiler.30978841_0
gcc --version
gcc (GCC) 11.2.0
Copyright (C) 2021 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
