I was compiling dcn_v2 code from GitHub - smallsunsun1/custom_ops: Deformable Convolution Networks(deformable conv2D TF_implementation) , but ran into following error:
nvlink fatal : Could not open input file '/usr/lib/x86_64-linux-gnu/librt.a'
make[2]: *** [CMakeFiles/ops.dir/build.make:132: CMakeFiles/ops.dir/cmake_device_link.o] Error 1
make[1]: *** [CMakeFiles/Makefile2:83: CMakeFiles/ops.dir/all] Error 2
make: *** [Makefile:91: all] Error 2
I’m using gcc 9.4.0 and tensorflow 2.8.0.
Here, is my cmake file:
cmake_minimum_required(VERSION 3.9)
set(CMAKE_CXX_STANDARD 14)
set(CMAKE_BUILD_TYPE Release)
set(CMAKE_CXX_FLAGS -march=native)
set(CUDA_LIBRARIES /usr/local/cuda-11.6/lib64)
set(CUDA_INCLUDE_DIRS /usr/local/cuda-11.6/include)
#set(CMAKE_CUDA_FLAGS "--expt-relaxed-constexpr")
#set(TF_INCLUDE_PATH /Users/sunjiahe/miniconda3/envs/tf2.0/lib/python3.6/site-packages/tensorflow_core/include)
set(TF_INCLUDE_PATH /home/vedanshu/.local/lib/python3.10/site-packages/tensorflow/include)
#add_definitions(-D__JETBRAINS_IDE__)
add_definitions(-DEIGEN_USE_THREADS)
option(USE_CUDA OFF)
set(USE_CUDA ON)
if (USE_CUDA)
add_definitions(-DGOOGLE_CUDA=1)
add_definitions(-DEIGEN_USE_GPU)
enable_language(CUDA)
find_package(CUDA REQUIRED)
set(CMAKE_CUDA_SEPARABLE_COMPILATION ON)
endif ()
#add_library(ops SHARED deform_conv_cuda_kernel.h deform_conv_cuda_kernel.cu deform_conv_cuda.cpp)
#add_library(ops SHARED deformable_conv2d.h deformable_conv2d_utils.h test.cpp)
add_library(ops SHARED deformable_conv2d.cpp deformable_conv.cu deformable_conv.cpp deformable_conv2d.h deformable_conv2d_utils.h)
target_include_directories(ops PUBLIC ${CUDA_INCLUDE_DIRS} ${TF_INCLUDE_PATH})
message(STATUS ${TF_INCLUDE_PATH})
#target_link_libraries(ops PRIVATE /Users/sunjiahe/miniconda3/envs/tf2.0/lib/python3.6/site-packages/tensorflow_core/libtensorflow_framework.dylib)
target_link_libraries(ops PUBLIC ${CUDA_LIBRARIES} /home/vedanshu/.local/lib/python3.10/site-packages/tensorflow/libtensorflow_framework.so.2)
#target_compile_options(ops PUBLIC -march=native)
