Hi all,
I am trying to port code from VS to unix. I was able to create all the .o but I get:
/usr/local/cuda-9.2/bin/nvcc -ccbin g++ -m64 -dc -gencode arch=compute_35,code=sm_35 -gencode arch=compute_35,code=compute_35 -o neuroGPU AllModels.o kernel.o MainC.o Util.o CudaStuff.o
nvcc fatal : A single input file is required for a non-link phase when an outputfile is specified
Makefile:302: recipe for target 'neuroGPU' failed
make: *** [neuroGPU] Error 1
Samples are working and I used a make file from the samples and moved the common directory so it will be where the include is pointing here is my makefile:
# Copyright 1993-2015 NVIDIA Corporation. All rights reserved.
# NOTICE TO USER:
# This source code is subject to NVIDIA ownership rights under U.S. and
# international Copyright laws.
# NVIDIA MAKES NO REPRESENTATION ABOUT THE SUITABILITY OF THIS SOURCE
# CODE FOR ANY PURPOSE. IT IS PROVIDED "AS IS" WITHOUT EXPRESS OR
# IMPLIED WARRANTY OF ANY KIND. NVIDIA DISCLAIMS ALL WARRANTIES WITH
# REGARD TO THIS SOURCE CODE, INCLUDING ALL IMPLIED WARRANTIES OF
# MERCHANTABILITY, NONINFRINGEMENT, AND FITNESS FOR A PARTICULAR PURPOSE.
# IN NO EVENT SHALL NVIDIA BE LIABLE FOR ANY SPECIAL, INDIRECT, INCIDENTAL,
# OR CONSEQUENTIAL DAMAGES, OR ANY DAMAGES WHATSOEVER RESULTING FROM LOSS
# OF USE, DATA OR PROFITS, WHETHER IN AN ACTION OF CONTRACT, NEGLIGENCE
# OR OTHER TORTIOUS ACTION, ARISING OUT OF OR IN CONNECTION WITH THE USE
# OR PERFORMANCE OF THIS SOURCE CODE.
# U.S. Government End Users. This source code is a "commercial item" as
# that term is defined at 48 C.F.R. 2.101 (OCT 1995), consisting of
# "commercial computer software" and "commercial computer software
# documentation" as such terms are used in 48 C.F.R. 12.212 (SEPT 1995)
# and is provided to the U.S. Government only as a commercial end item.
# Consistent with 48 C.F.R.12.212 and 48 C.F.R. 227.7202-1 through
# 227.7202-4 (JUNE 1995), all U.S. Government End Users acquire the
# source code with only those rights set forth herein.
# Makefile project only supported on Mac OS X and Linux Platforms)
# Location of the CUDA Toolkit
CUDA_PATH ?= /usr/local/cuda-9.2
# start deprecated interface #
ifeq ($(x86_64),1)
$(info WARNING - x86_64 variable has been deprecated)
$(info WARNING - please use TARGET_ARCH=x86_64 instead)
TARGET_ARCH ?= x86_64
endif
ifeq ($(ARMv7),1)
$(info WARNING - ARMv7 variable has been deprecated)
$(info WARNING - please use TARGET_ARCH=armv7l instead)
TARGET_ARCH ?= armv7l
endif
ifeq ($(aarch64),1)
$(info WARNING - aarch64 variable has been deprecated)
$(info WARNING - please use TARGET_ARCH=aarch64 instead)
TARGET_ARCH ?= aarch64
endif
ifeq ($(ppc64le),1)
$(info WARNING - ppc64le variable has been deprecated)
$(info WARNING - please use TARGET_ARCH=ppc64le instead)
TARGET_ARCH ?= ppc64le
endif
ifneq ($(GCC),)
$(info WARNING - GCC variable has been deprecated)
$(info WARNING - please use HOST_COMPILER=$(GCC) instead)
HOST_COMPILER ?= $(GCC)
endif
ifneq ($(abi),)
$(error ERROR - abi variable has been removed)
endif
# end deprecated interface #
# architecture
HOST_ARCH := $(shell uname -m)
TARGET_ARCH ?= $(HOST_ARCH)
ifneq (,$(filter $(TARGET_ARCH),x86_64 aarch64 ppc64le armv7l))
ifneq ($(TARGET_ARCH),$(HOST_ARCH))
ifneq (,$(filter $(TARGET_ARCH),x86_64 aarch64 ppc64le))
TARGET_SIZE := 64
else ifneq (,$(filter $(TARGET_ARCH),armv7l))
TARGET_SIZE := 32
endif
else
TARGET_SIZE := $(shell getconf LONG_BIT)
endif
else
$(error ERROR - unsupported value $(TARGET_ARCH) for TARGET_ARCH!)
endif
ifeq (,$(filter $(HOST_ARCH)-$(TARGET_ARCH),aarch64-armv7l x86_64-armv7l x86_64-aarch64 x86_64-ppc64le))
$(error ERROR - cross compiling from $(HOST_ARCH) to $(TARGET_ARCH) is not supported!)
endif
endif
# When on native aarch64 system with userspace of 32-bit, change TARGET_ARCH to armv7l
ifeq ($(HOST_ARCH)-$(TARGET_ARCH)-$(TARGET_SIZE),aarch64-aarch64-32)
TARGET_ARCH = armv7l
endif
# operating system
HOST_OS := $(shell uname -s 2>/dev/null | tr "[:upper:]" "[:lower:]")
TARGET_OS ?= $(HOST_OS)
ifeq (,$(filter $(TARGET_OS),linux darwin qnx android))
$(error ERROR - unsupported value $(TARGET_OS) for TARGET_OS!)
endif
# host compiler
ifeq ($(TARGET_OS),darwin)
ifeq ($(shell expr `xcodebuild -version | grep -i xcode | awk '{print $$2}' | cut -d'.' -f1` \>= 5),1)
HOST_COMPILER ?= clang++
endif
else ifneq ($(TARGET_ARCH),$(HOST_ARCH))
ifeq ($(HOST_ARCH)-$(TARGET_ARCH),x86_64-armv7l)
ifeq ($(TARGET_OS),linux)
HOST_COMPILER ?= arm-linux-gnueabihf-g++
else ifeq ($(TARGET_OS),qnx)
ifeq ($(QNX_HOST),)
$(error ERROR - QNX_HOST must be passed to the QNX host toolchain)
endif
ifeq ($(QNX_TARGET),)
$(error ERROR - QNX_TARGET must be passed to the QNX target toolchain)
endif
export QNX_HOST
export QNX_TARGET
HOST_COMPILER ?= $(QNX_HOST)/usr/bin/arm-unknown-nto-qnx6.6.0eabi-g++
else ifeq ($(TARGET_OS),android)
HOST_COMPILER ?= arm-linux-androideabi-g++
endif
else ifeq ($(TARGET_ARCH),aarch64)
ifeq ($(TARGET_OS), linux)
HOST_COMPILER ?= aarch64-linux-gnu-g++
ifeq ($(QNX_HOST),)
endif
endif
export QNX_HOST
export QNX_TARGET
HOST_COMPILER ?= $(QNX_HOST)/usr/bin/aarch64-unknown-nto-qnx7.0.0-g++
else ifeq ($(TARGET_OS), android)
HOST_COMPILER ?= aarch64-linux-android-g++
endif
else ifeq ($(TARGET_ARCH),ppc64le)
HOST_COMPILER ?= powerpc64le-linux-gnu-g++
endif
endif
HOST_COMPILER ?= g++
NVCC := $(CUDA_PATH)/bin/nvcc -ccbin $(HOST_COMPILER)
# internal flags
NVCCFLAGS := -m${TARGET_SIZE} -dc
CCFLAGS :=
LDFLAGS :=
# build flags
LDFLAGS += -rpath $(CUDA_PATH)/lib
CCFLAGS += -arch $(HOST_ARCH)
else ifeq ($(HOST_ARCH)-$(TARGET_ARCH)-$(TARGET_OS),x86_64-armv7l-linux)
LDFLAGS += --dynamic-linker=/lib/ld-linux-armhf.so.3
CCFLAGS += -mfloat-abi=hard
LDFLAGS += -pie
CCFLAGS += -fpie -fpic -fexceptions
endif
ifeq ($(TARGET_ARCH)-$(TARGET_OS),armv7l-linux)
ifneq ($(TARGET_FS),)
GCCVERSIONLTEQ46 := $(shell expr `$(HOST_COMPILER) -dumpversion` \<= 4.6)
ifeq ($(GCCVERSIONLTEQ46),1)
CCFLAGS += --sysroot=$(TARGET_FS)
endif
LDFLAGS += --sysroot=$(TARGET_FS)
LDFLAGS += -rpath-link=$(TARGET_FS)/lib
LDFLAGS += -rpath-link=$(TARGET_FS)/usr/lib
LDFLAGS += -rpath-link=$(TARGET_FS)/usr/lib/arm-linux-gnueabihf
endif
endif
ifeq ($(TARGET_ARCH)-$(TARGET_OS),aarch64-linux)
endif
LDFLAGS += -rpath-link=$(TARGET_FS)/lib -L $(TARGET_FS)/lib
LDFLAGS += -rpath-link=$(TARGET_FS)/usr/lib -L $(TARGET_FS)/usr/lib
LDFLAGS += -rpath-link=$(TARGET_FS)/usr/lib/aarch64-linux-gnu -L $(TARGET_FS)/usr/lib/aarch64-linux-gnu
LDFLAGS += --unresolved-symbols=ignore-in-shared-libs
CCFLAGS += -isystem=$(TARGET_FS)/usr/include
CCFLAGS += -isystem=$(TARGET_FS)/usr/include/aarch64-linux-gnu
endif
endif
endif
CCFLAGS += -DWIN_INTERFACE_CUSTOM
LDFLAGS += -lsocket
endif
# Install directory of different arch
CUDA_INSTALL_TARGET_DIR :=
CUDA_INSTALL_TARGET_DIR = targets/armv7-linux-gnueabihf/
else ifeq ($(TARGET_ARCH)-$(TARGET_OS),aarch64-linux)
CUDA_INSTALL_TARGET_DIR = targets/aarch64-linux/
else ifeq ($(TARGET_ARCH)-$(TARGET_OS),armv7l-android)
CUDA_INSTALL_TARGET_DIR = targets/armv7-linux-androideabi/
else ifeq ($(TARGET_ARCH)-$(TARGET_OS),aarch64-android)
CUDA_INSTALL_TARGET_DIR = targets/aarch64-linux-androideabi/
else ifeq ($(TARGET_ARCH)-$(TARGET_OS),armv7l-qnx)
CUDA_INSTALL_TARGET_DIR = targets/ARMv7-linux-QNX/
else ifeq ($(TARGET_ARCH)-$(TARGET_OS),aarch64-qnx)
CUDA_INSTALL_TARGET_DIR = targets/aarch64-qnx/
CUDA_INSTALL_TARGET_DIR = targets/ppc64le-linux/
endif
# Debug build flags
ifeq ($(dbg),1)
NVCCFLAGS += -g -G
BUILD_TYPE := debug
else
BUILD_TYPE := release
endif
ALL_CCFLAGS :=
ALL_CCFLAGS += $(NVCCFLAGS)
ALL_CCFLAGS += $(EXTRA_NVCCFLAGS)
ALL_CCFLAGS += $(addprefix -Xcompiler ,$(CCFLAGS))
ALL_CCFLAGS += $(addprefix -Xcompiler ,$(EXTRA_CCFLAGS))
SAMPLE_ENABLED := 1
ALL_LDFLAGS :=
ALL_LDFLAGS += $(ALL_CCFLAGS)
ALL_LDFLAGS += $(addprefix -Xlinker ,$(LDFLAGS))
ALL_LDFLAGS += $(addprefix -Xlinker ,$(EXTRA_LDFLAGS))
# Common includes and paths for CUDA
INCLUDES := -I../../common/inc
LIBRARIES :=
# Gencode arguments
SMS ?= 35
ifeq ($(SMS),)
$(info >>> WARNING - no SM architectures have been specified - waiving sample <<<)
SAMPLE_ENABLED := 0
endif
ifeq ($(GENCODE_FLAGS),)
# Generate SASS code for each SM architecture listed in $(SMS)
$(foreach sm,$(SMS),$(eval GENCODE_FLAGS += -gencode arch=compute_$(sm),code=sm_$(sm)))
# Generate PTX code from the highest SM architecture in $(SMS) to guarantee forward-compatibility
HIGHEST_SM := $(lastword $(sort $(SMS)))
ifneq ($(HIGHEST_SM),)
GENCODE_FLAGS += -gencode arch=compute_$(HIGHEST_SM),code=compute_$(HIGHEST_SM)
endif
endif
ifeq ($(SAMPLE_ENABLED),0)
EXEC ?= @echo "[@]"
endif
# Target rules
all: build
build: neuroGPU
check.deps:
@echo "Sample will be waived due to the above missing dependencies"
else
@echo "Sample is ready - all dependencies have been met"
endif
CudaStuff.o:CudaStuff.cu
$(EXEC) $(NVCC) $(INCLUDES) $(ALL_CCFLAGS) $(GENCODE_FLAGS) -o $@ -c $<
AllModels.o:AllModels.cu
Util.o:Util.cu Util.h
MainC.o:MainC.cu
kernel.o:kernel.cu
neuroGPU: AllModels.o kernel.o MainC.o Util.o CudaStuff.o
$(EXEC) $(NVCC) $(ALL_LDFLAGS) $(GENCODE_FLAGS) -o $@ $+ $(LIBRARIES)
$(EXEC) mkdir -p ../../bin/$(TARGET_ARCH)/$(TARGET_OS)/$(BUILD_TYPE)
$(EXEC) cp $@ ../../bin/$(TARGET_ARCH)/$(TARGET_OS)/$(BUILD_TYPE)
run: build
$(EXEC) ./neuroGPU
clean:
rm -f neuroGPU kernel.o MainC.o Util.o CudaStuff.o AllModels.o
rm -rf ../../bin/$(TARGET_ARCH)/$(TARGET_OS)/$(BUILD_TYPE)/neuroGPU
clobber: clean
Thanks in advance
Roy
