I dont see the common.mk attachment file anywhere so here it is:
[codebox]###################################################
Copyright 1993-2009 NVIDIA Corporation. All rights reserved.
NVIDIA Corporation and its licensors retain all intellectual property and
proprietary rights in and to this software and related documentation.
Any use, reproduction, disclosure, or distribution of this software
and related documentation without an express license agreement from
NVIDIA Corporation is strictly prohibited.
Please refer to the applicable NVIDIA end user license agreement (EULA)
associated with this source code for terms and conditions that govern
your use of this NVIDIA software.
Common build script for CUDA source projects for Linux and Mac platforms
Environment variables used by XCode Build process
OBJECT_FILE_DIR
BUILD_DIR
CONFiGURATION
.SUFFIXES : .cu .cu_dbg.o .c_dbg.o .cpp_dbg.o .cu_rel.o .c_rel.o .cpp_rel.o .cubin .ptx .m .mm
Add new SM Versions here as devices with new Compute Capability are released
SM_VERSIONS := sm_10 sm_11 sm_12 sm_13
CUDA_INSTALL_PATH ?= /usr/local/cuda
ifdef cuda-install
CUDA_INSTALL_PATH := $(cuda-install)
endif
detect OS
OSUPPER = $(shell uname -s 2>/dev/null | tr [:lower:] [:upper:])
OSLOWER = $(shell uname -s 2>/dev/null | tr [:upper:] [:lower:])
‘linux’ is output for Linux system, ‘darwin’ for OS X
DARWIN = $(strip $(findstring DARWIN, $(OSUPPER)))
ifneq ($(DARWIN),)
SNOWLEOPARD = $(strip $(findstring 10.6, $(shell egrep “10.6” /System/Library/CoreServices/SystemVersion.plist)))
endif
detect 32-bit or 64-bit platform
HP_64 = $(shell uname -m | grep 64)
OSARCH= $(shell uname -m)
Basic directory setup for SDK
(override directories only if they are not already defined)
SRCDIR ?= ./
ROOTDIR ?= .
ROOTBINDIR ?= $(ROOTDIR)/bin
BINDIR ?= $(ROOTBINDIR)/$(OSLOWER)
COMMONDIR := $(ROOTDIR)/common
LIBDIR := $(ROOTDIR)/lib
ROOTOBJDIR ?= obj
LIBDIR := $(BUILD_DIR)/$(CONFIGURATION)
ROOTOBJDIR ?= $(OBJECT_FILE_DIR)
Compilers
NVCC := $(CUDA_INSTALL_PATH)/bin/nvcc
CXX := g++
CC := gcc
LINK := g++ -fPIC
DYLINK := g++ -fPIC
Includes
INCLUDES += -I. -I$(CUDA_INSTALL_PATH)/include -I$(COMMONDIR)/inc
Warning flags
CXXWARN_FLAGS := \
-W -Wall \
-Wimplicit \
-Wswitch \
-Wformat \
-Wchar-subscripts \
-Wparentheses \
-Wmultichar \
-Wtrigraphs \
-Wpointer-arith \
-Wcast-align \
-Wreturn-type \
-Wno-unused-function \
$(SPACE)
CWARN_FLAGS := $(CXXWARN_FLAGS) \
-Wstrict-prototypes \
-Wmissing-prototypes \
-Wmissing-declarations \
-Wnested-externs \
-Wmain \
architecture flag for nvcc and gcc compilers build
CUBIN_ARCH_FLAG :=
CXX_ARCH_FLAGS :=
NVCCFLAGS :=
LIB_ARCH := $(OSARCH)
set NVCC to use ptxas verbose mode so we can see how each kernel uses device memory/registers
NVCCFLAGS += --ptxas-options=-v
Determining the necessary Cross-Compilation Flags
32-bit OS, but we target 64-bit cross compilation
ifeq ($(x86_64),1)
NVCCFLAGS += -m64
LIB_ARCH = x86_64
ifneq ($(DARWIN),)
CXX_ARCH_FLAGS += -arch x86_64
else
CXX_ARCH_FLAGS += -m64
endif
else
64-bit OS, and we target 32-bit cross compilation
ifeq ($(i386),1)
NVCCFLAGS += -m32
LIB_ARCH = i386
ifneq ($(DARWIN),)
CXX_ARCH_FLAGS += -arch i386
else
CXX_ARCH_FLAGS += -m32
endif
else
ifneq ($(SNOWLEOPARD),)
NVCCFLAGS += -m32
CXX_ARCH_FLAGS += -arch i386 -m32
LIB_ARCH = i386
endif
endif
endif
Compiler-specific flags
CXXFLAGS := $(CXXWARN_FLAGS) $(CXX_ARCH_FLAGS)
CFLAGS := $(CWARN_FLAGS) $(CXX_ARCH_FLAGS)
LINK += $(CXX_ARCH_FLAGS)
DYLINK += $(CXX_ARCH_FLAGS)
This option for Mac allows CUDA applications to work without requiring to set DYLD_LIBRARY_PATH
ifneq ($(DARWIN),)
LINK += -Xlinker -rpath $(CUDA_INSTALL_PATH)/lib -Xlinker -no_compact_linkedit
DYLINK += -Xlinker -rpath $(CUDA_INSTALL_PATH)/lib -Xlinker -no_compact_linkedit
endif
Common flags
COMMONFLAGS += $(INCLUDES) -DUNIX
Debug/release configuration
ifeq ($(dbg),1)
COMMONFLAGS += -g
NVCCFLAGS += -D_DEBUG
CXXFLAGS += -D_DEBUG -x objective-c++
CFLAGS += -D_DEBUG -x objective-c
BINSUBDIR := debug
#LIBSUFFIX := D
LIBSUFFIX :=
else
COMMONFLAGS += -O2
BINSUBDIR := release
LIBSUFFIX :=
NVCCFLAGS += --compiler-options -fno-strict-aliasing
CXXFLAGS += -fno-strict-aliasing -x objective-c++
CFLAGS += -fno-strict-aliasing -x objective-c
endif
architecture flag for cubin build
CUBIN_ARCH_FLAG :=
OpenGL is used or not (if it is used, then it is necessary to include GLEW)
ifeq ($(USEGLLIB),1)
ifneq ($(DARWIN),)
OPENGLLIB := -L/System/Library/Frameworks/OpenGL.framework/Libraries
OPENGLLIB += -lGL -lGLU $(COMMONDIR)/lib/$(OSLOWER)/libGLEW.a
else
this case for linux platforms
OPENGLLIB := -lGL -lGLU -lX11 -lXi -lXmu
check if x86_64 flag has been set, otherwise, check HP_64 is i386/x86_64
ifeq ($(x86_64),1)
OPENGLLIB += -lGLEW_x86_64 -L/usr/X11R6/lib64
else
ifeq ($(i386),)
ifeq "$(strip $(HP_64))" ""
OPENGLLIB += -lGLEW -L/usr/X11R6/lib
else
endif
endif
endif
check if i386 flag has been set, otehrwise check HP_64 is i386/x86_64
ifeq ($(i386),1)
else
ifeq ($(x86_64),)
else
endif
endif
endif
endif
endif
ifeq ($(USEGLUT),1)
ifneq ($(DARWIN),)
OPENGLLIB += -framework GLUT
else
ifeq ($(x86_64),1)
OPENGLLIB += -lglut -L/usr/lib64
endif
ifeq ($(i386),1)
endif
ifeq ($(x86_64),)
ifeq ($(i386),)
OPENGLLIB += -lglut
endif
endif
endif
endif
ifeq ($(USEPARAMGL),1)
PARAMGLLIB := -lparamgl_$(LIB_ARCH)$(LIBSUFFIX)
endif
ifeq ($(USERENDERCHECKGL),1)
RENDERCHECKGLLIB := -lrendercheckgl_$(LIB_ARCH)$(LIBSUFFIX)
endif
ifeq ($(USECUDPP), 1)
ifeq ($(x86_64),1)
CUDPPLIB := -lcudpp64
else
CUDPPLIB := -lcudpp
else
CUDPPLIB := -lcudpp
else
endif
endif
endif
ifeq ($(i386),1)
CUDPPLIB := -lcudpp
else
CUDPPLIB := -lcudpp
else
CUDPPLIB := -lcudpp
else
endif
endif
endif
CUDPPLIB := $(CUDPPLIB)$(LIBSUFFIX)
ifeq ($(emu), 1)
CUDPPLIB := $(CUDPPLIB)_emu
endif
endif
ifeq ($(USENVCUVID), 1)
ifneq ($(DARWIN),)
NVCUVIDLIB := -L../../common/lib/darwin -lnvcuvid
endif
endif
Libs
ifneq ($(DARWIN),)
LIB := -L$(CUDA_INSTALL_PATH)/lib -L$(LIBDIR) -L$(COMMONDIR)/lib/$(OSLOWER) $(NVCUVIDLIB)
else
ifeq “$(strip $(HP_64))” “”
ifeq ($(x86_64),1)
LIB := -L$(CUDA_INSTALL_PATH)/lib64 -L$(LIBDIR) -L$(COMMONDIR)/lib/$(OSLOWER)
else
endif
else
ifeq ($(i386),1)
else
endif
endif
endif
If dynamically linking to CUDA and CUDART, we exclude the libraries from the LIB
ifeq ($(USECUDADYNLIB),1)
LIB += ${OPENGLLIB} $(PARAMGLLIB) $(RENDERCHECKGLLIB) $(CUDPPLIB) ${LIB} -ldl -rdynamic
else
static linking, we will statically link against CUDA and CUDART
ifeq ($(USEDRVAPI),1)
LIB += -lcuda ${OPENGLLIB} $(PARAMGLLIB) $(RENDERCHECKGLLIB) $(CUDPPLIB) ${LIB}
else
LIB += -lcudart ${OPENGLLIB} $(PARAMGLLIB) $(RENDERCHECKGLLIB) $(CUDPPLIB) ${LIB}
endif
endif
ifeq ($(USECUFFT),1)
ifeq ($(emu),1)
LIB += -lcufftemu
else
LIB += -lcufft
endif
endif
ifeq ($(USECUBLAS),1)
ifeq ($(emu),1)
LIB += -lcublasemu
else
LIB += -lcublas
endif
endif
ifneq ($(FRAMEWORKS),)
LIB += $(patsubst %,-framework %,$(notdir $(FRAMEWORKS)))
endif
Lib/exe configuration
ifneq ($(STATIC_LIB),)
TARGETDIR := $(LIBDIR)
TARGET := $(subst .a,_$(LIB_ARCH)$(LIBSUFFIX).a,$(LIBDIR)/$(STATIC_LIB))
LINKLINE = ar rucv $(TARGET) $(OBJS)
else ifneq ($(DYNAMIC_LIB),)
TARGET := $(subst .dylib,_$(LIB_ARCH)$(LIBSUFFIX).dylib,$(LIBDIR)/$(DYNAMIC_LIB))
TARGETLIB := $(subst .dylib,_$(LIB_ARCH)$(LIBSUFFIX).dylib,$(DYNAMIC_LIB))
LINKLINE = $(DYLINK) -dynamiclib -install_name "@executable_path/../Frameworks/$(TARGETLIB)" -o $(TARGET) $(OBJS) $(LIB)
else
ifneq ($(OMIT_CUTIL_LIB),1)
LIB += -lcutil_$(LIB_ARCH)$(LIBSUFFIX)
endif
# Device emulation configuration
ifeq ($(emu), 1)
NVCCFLAGS += -deviceemu
CUDACCFLAGS +=
BINSUBDIR := emu$(BINSUBDIR)
# consistency, makes developing easier
CXXFLAGS += -D__DEVICE_EMULATION__
CFLAGS += -D__DEVICE_EMULATION__
endif
TARGETDIR := $(BINDIR)/$(BINSUBDIR)
TARGET := $(TARGETDIR)/$(EXECUTABLE)
LINKLINE = $(LINK) -o $(TARGET) $(OBJS) $(LIB)
endif
check if verbose
ifeq ($(verbose), 1)
VERBOSE :=
else
VERBOSE := @
endif
Check for input flags and set compiler flags appropriately
ifeq ($(fastmath), 1)
NVCCFLAGS += -use_fast_math
endif
ifeq ($(keep), 1)
NVCCFLAGS += -keep
NVCC_KEEP_CLEAN := *.i* *.cubin *.cu.c *.cudafe* *.fatbin.c *.ptx
endif
ifdef maxregisters
NVCCFLAGS += -maxrregcount $(maxregisters)
endif
Add cudacc flags
NVCCFLAGS += $(CUDACCFLAGS)
Add common flags
NVCCFLAGS += $(COMMONFLAGS)
CXXFLAGS += $(COMMONFLAGS)
ifeq ($(nvcc_warn_verbose),1)
NVCCFLAGS += $(addprefix --compiler-options ,$(CXXWARN_FLAGS))
endif
Set up object files
OBJDIR := $(ROOTOBJDIR)/$(LIB_ARCH)/$(BINSUBDIR)
OBJS += $(patsubst %.cpp,$(OBJDIR)/%.cpp.o,$(notdir $(CCFILES)))
OBJS += $(patsubst %.c,$(OBJDIR)/%.c.o,$(notdir $(CFILES)))
OBJS += $(patsubst %.cu,$(OBJDIR)/%.cu.o,$(notdir $(CUFILES)))
OBJS += $(patsubst %.m,$(OBJDIR)/%.m.o,$(notdir $(MFILES)))
OBJS += $(patsubst %.mm,$(OBJDIR)/%.mm.o,$(notdir $(MMFILES)))
Set up cubin output files
CUBINDIR := $(SRCDIR)data
CUBINS += $(patsubst %.cu,$(CUBINDIR)/%.cubin,$(notdir $(CUBINFILES)))
Set up PTX output files
PTXDIR := $(SRCDIR)data
PTXBINS += $(patsubst %.cu,$(PTXDIR)/%.ptx,$(notdir $(PTXFILES)))
Rules
$(OBJDIR)/%.c.o : $(SRCDIR)%.c $(C_DEPS)
$(VERBOSE)$(CC) $(CFLAGS) -o $@ -c $<
$(OBJDIR)/%.cpp.o : $(SRCDIR)%.cpp $(C_DEPS)
$(VERBOSE)$(CXX) $(CXXFLAGS) -o $@ -c $<
$(OBJDIR)/%.m.o : $(SRCDIR)%.m $(C_DEPS)
$(VERBOSE)$(CXX) $(CFLAGS) -o $@ -c $<
$(OBJDIR)/%.mm.o : $(SRCDIR)%.mm $(C_DEPS)
$(OBJDIR)/%.cu.o : $(SRCDIR)%.cu $(CU_DEPS)
$(VERBOSE)$(NVCC) $(NVCCFLAGS) $(SMVERSIONFLAGS) -o $@ -c $<
$(CUBINDIR)/%.cubin : $(SRCDIR)%.cu cubindirectory
$(VERBOSE)$(NVCC) $(CUBIN_ARCH_FLAG) $(NVCCFLAGS) $(SMVERSIONFLAGS) -o $@ -cubin $<
$(PTXDIR)/%.ptx : $(SRCDIR)%.cu ptxdirectory
$(VERBOSE)$(NVCC) $(CUBIN_ARCH_FLAG) $(NVCCFLAGS) $(SMVERSIONFLAGS) -o $@ -ptx $<
The following definition is a template that gets instantiated for each SM
version (sm_10, sm_13, etc.) stored in SMVERSIONS. It does 2 things:
1. It adds to OBJS a .cu_sm_XX.o for each .cu file it finds in CUFILES_sm_XX.
2. It generates a rule for building .cu_sm_XX.o files from the corresponding
.cu file.
The intended use for this is to allow Makefiles that use common.mk to compile
files to different Compute Capability targets (aka SM arch version). To do
so, in the Makefile, list files for each SM arch separately, like so:
CUFILES_sm_10 := mycudakernel_sm10.cu app.cu
CUFILES_sm_12 := anothercudakernel_sm12.cu
define SMVERSION_template
OBJS += $(patsubst %.cu,$(OBJDIR)/%.cu_$(1).o,$(notdir $(CUFILES_$(1))))
$(OBJDIR)/%.cu_$(1).o : $(SRCDIR)%.cu $(CU_DEPS)
$(VERBOSE)$(NVCC) -o $$@ -c $$< $(NVCCFLAGS) -arch $(1)
endef
This line invokes the above template for each arch version stored in
SM_VERSIONS. The call funtion invokes the template, and the eval
function interprets it as make commands.
$(foreach smver,$(SM_VERSIONS),$(eval $(call SMVERSION_template,$(smver))))
$(TARGET): makedirectories $(OBJS) $(CUBINS) $(PTXBINS) Makefile
$(VERBOSE)$(LINKLINE)
cubindirectory:
$(VERBOSE)mkdir -p $(CUBINDIR)
ptxdirectory:
$(VERBOSE)mkdir -p $(PTXDIR)
makedirectories:
$(VERBOSE)mkdir -p $(LIBDIR)
$(VERBOSE)mkdir -p $(OBJDIR)
$(VERBOSE)mkdir -p $(TARGETDIR)
tidy :
$(VERBOSE)find . | egrep "#" | xargs rm -f
$(VERBOSE)find . | egrep "\~" | xargs rm -f
clean : tidy
$(VERBOSE)rm -f $(OBJS)
$(VERBOSE)rm -f $(CUBINS)
$(VERBOSE)rm -f $(PTXBINS)
$(VERBOSE)rm -f $(TARGET)
$(VERBOSE)rm -f $(NVCC_KEEP_CLEAN)
$(VERBOSE)rm -f $(ROOTBINDIR)/$(OSLOWER)/$(BINSUBDIR)/*.ppm
$(VERBOSE)rm -f $(ROOTBINDIR)/$(OSLOWER)/$(BINSUBDIR)/*.pgm
$(VERBOSE)rm -f $(ROOTBINDIR)/$(OSLOWER)/$(BINSUBDIR)/*.bin
$(VERBOSE)rm -f $(ROOTBINDIR)/$(OSLOWER)/$(BINSUBDIR)/*.bmp
clobber : clean
$(VERBOSE)rm -rf $(ROOTOBJDIR)
[/codebox]
