Add include path “/usr/include” in Properties/Build/Settings/Tool settings/NVCC Compiler/includes.
And Add library path “/usr/lib” and libraries “libopencv_core.so libopencv_highgui.so etc” in Properties/Build/Settings/Tool settings/NVCC Linker/Libraries.
And Add LD_LIBRARY_PATH "LD_LIBRARY_PATH /usr/lib/"in Properties/Build/Environment.
I tried your idea in nsight on HOST-PC as below.
property/Build/Settings/NVCC COmpiler/symbols/Defined symbols(-D) CUDA_USE_STATIC_RUNTIME=false
I had to tell more info. that OpenCV isn’t installed on HOST-PC, but OpenCV4Tegra is installed on TegraX1,
and the main() function doesn’t include GPU function at all.
I’ll attatch nsight’s messages here.
Can you see any problems?
I’m not sure TegraX1 recognize “/usr/lib” path I’ve set despite I’ve set it on HOST-PC’s nsight.
09:52:16 **** Build of configuration Release for project OpenCVSample ****
make all -C /home/ubuntu/cuda-workspace/Release
make: Entering directory ‘/home/ubuntu/cuda-workspace/Release’
Building file: …/SampleOpenCV.cpp
Invoking: NVCC Compiler
/usr/local/cuda-8.0/bin/nvcc -DCUDA_USE_STASTIC_CUDA_RUNTIME=false -I/usr/include -O3 -v -ccbin aarch64-linux-gnu-g++ -gencode arch=compute_20,code=sm_20 -m64 -odir “.” -M -o “SampleOpenCV.d” “…/SampleOpenCV.cpp”
nvcc warning : The ‘compute_20’, ‘sm_20’, and ‘sm_21’ architectures are deprecated, and may be removed in a future release (Use -Wno-deprecated-gpu-targets to suppress warning).
#$ SPACE=
#$ CUDART=cudart
#$ HERE=/usr/local/cuda-8.0/bin
#$ THERE=/usr/local/cuda-8.0/bin
#$ TARGET_SIZE=
#$ TARGET_DIR=
#$ TARGET_DIR=targets/aarch64-linux
#$ TOP=/usr/local/cuda-8.0/bin/…
#$ NVVMIR_LIBRARY_DIR=/usr/local/cuda-8.0/bin/…/nvvm/libdevice
#$ LD_LIBRARY_PATH=/usr/local/cuda-8.0/bin/…/lib:
#$ PATH=/usr/local/cuda-8.0/bin/…/open64/bin:/usr/local/cuda-8.0/bin/…/nvvm/bin:/usr/local/cuda-8.0/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
#$ INCLUDES=“-I/usr/local/cuda-8.0/bin/…/targets/aarch64-linux/include”
#$ LIBRARIES= “-L/usr/local/cuda-8.0/bin/…/targets/aarch64-linux/lib/stubs” “-L/usr/local/cuda-8.0/bin/…/targets/aarch64-linux/lib”
#$ CUDAFE_FLAGS=
#$ PTXAS_FLAGS=
#$ aarch64-linux-gnu-g++ -E -x c++ -D__NVCC__ -O3 -I"/usr/include" “-I/usr/local/cuda-8.0/bin/…/targets/aarch64-linux/include” -D"CUDACC_VER=80033" -D"CUDACC_VER_BUILD=33" -D"CUDACC_VER_MINOR=0" -D"CUDACC_VER_MAJOR=8" -D"CUDA_USE_STASTIC_CUDA_RUNTIME=false" “…/SampleOpenCV.cpp” > “/tmp/tmpxft_00000fa7_00000000-2_SampleOpenCV.ii”
#$ – Filter Dependencies – > SampleOpenCV.d
/usr/local/cuda-8.0/bin/nvcc -DCUDA_USE_STASTIC_CUDA_RUNTIME=false -I/usr/include -O3 -v --compile -m64 -ccbin aarch64-linux-gnu-g++ -x c++ -o “SampleOpenCV.o” “…/SampleOpenCV.cpp”
#$ SPACE=
#$ CUDART=cudart
#$ TARGET_SIZE=
#$ TARGET_DIR=
#$ CUDAFE_FLAGS=
#$ PTXAS_FLAGS=
#$ aarch64-linux-gnu-g++ -c -x c++ -D__NVCC__ -O3 -I"/usr/include" “-I/usr/local/cuda-8.0/bin/…/targets/aarch64-linux/include” -D"CUDACC_VER=80033" -D"CUDACC_VER_BUILD=33" -D"CUDACC_VER_MINOR=0" -D"CUDACC_VER_MAJOR=8" -D"CUDA_USE_STASTIC_CUDA_RUNTIME=false" -o “SampleOpenCV.o” “…/SampleOpenCV.cpp”
Finished building: …/SampleOpenCV.cpp
Building target: OpenCVSample
Invoking: NVCC Linker
/usr/local/cuda-8.0/bin/nvcc --cudart static -L/usr/lib --relocatable-device-code=false -gencode arch=compute_20,code=compute_20 -gencode arch=compute_20,code=sm_20 -m64 -ccbin aarch64-linux-gnu-g++ -link -o “OpenCVSample” ./SampleOpenCV.o -llibopencv_core.so -llibopencv_gpu.so -llibopencv_highgui.so
/usr/bin/ld: cannot find -llibopencv_core.so
/usr/bin/ld: cannot find -llibopencv_gpu.so
/usr/bin/ld: cannot find -llibopencv_highgui.so
collect2: error: ld returned 1 exit status
makefile:58: recipe for target ‘OpenCVSample’ failed
make: *** [OpenCVSample] Error 1
make: Leaving directory ‘/home/ubuntu/cuda-workspace/Release’
