I am trying to implement a cuda application that convert a packed UYVY image to 3 channel packed RGB image cv::Mat.
So I tried with the code below:
#include <iterator>
#include <fstream>
#include <iostream>
#include "opencv2/opencv.hpp"
#include "nppdefs.h"
#include "nppi_support_functions.h"
#include "nppi_color_conversion.h"
int main()
cv::Size raw_size(1920, 1080);
unsigned char *raw_data = new unsigned char[raw_size.width * raw_size.height * 2];
cv::Mat raw_mat(raw_size, CV_8UC2, raw_data);
std::string raw_file("camid_1_count_1.raw");
std::ifstream raw_stream;
raw_stream.open(raw_file, std::ios::in | std::ios::binary);
if (!raw_stream.is_open())
std::cerr << "[ERROR] cannot open the raw file " << raw_file << std::endl;
std::cerr << std::endl;
assert(0);
raw_stream.read((char*)raw_data, sizeof(unsigned char)*raw_size.width*raw_size.height*2);
raw_stream.close();
cv::Mat rgb_mat;
cv::cuda::GpuMat gpu_raw_mat;
int step;
Npp8u* gpu_rgb_data = nppiMalloc_8u_C3(raw_size.width, raw_size.height, &step);
gpu_raw_mat.upload(raw_mat);
NppiSize ROI = {raw_size.width, raw_size.height};
NppStatus status = NppStatus::NPP_NO_ERROR;//0
try {
std::cout << "gpu_raw_mat.step: " << gpu_raw_mat.step << std::endl;
status = nppiYUV422ToRGB_8u_C2C3R(gpu_raw_mat.ptr<Npp8u>(),
//3840,
gpu_raw_mat.step, // <<< really?
gpu_rgb_data,
step,
ROI);
} catch( cv::Exception& e ) {
const char* err_msg = e.what();
std::cout << "exception caught #1: " << err_msg << std::endl;
std::cout << "NppStatus : " << status << std::endl;
cv::cuda::GpuMat gpu_rgb_mat(raw_size.height, raw_size.width, CV_8UC3, gpu_rgb_data);
std::cout << "[BEFORE]" << std::endl;
std::cout << "depth : " << rgb_mat.depth() << std::endl;
std::cout << "channels : " << rgb_mat.channels() << std::endl;
std::cout << "elemSize : " << rgb_mat.elemSize() << std::endl;
std::cout << "step1 : " << rgb_mat.step1() << std::endl;
std::cout << "type : " << rgb_mat.type() << std::endl;
gpu_rgb_mat.download(rgb_mat);
std::cout << "[AFTER]" << std::endl;
try {
cv::imshow("RGB Image", rgb_mat);
std::cout << "exception caught #2: " << err_msg << std::endl;
cv::waitKey(0);
delete[] raw_data;
return 0;
And the experiment with the code above displays an image but the image is not a correct one. Maybe something is wrong so the image is all messed up. And it prints output message like shown below:
gpu_raw_mat.step: 4096
NppStatus : 0
[BEFORE]
depth : 0
channels : 1
elemSize : 0
step1 : 0
type : 0
[AFTER]
depth : 0
channels : 3
elemSize : 3
step1 : 5760
type : 16
I don’t know what I did wrong…
I’d like someone point me what is wrong… And what is expected way to write good code to do nppiYUV422ToRGB_8u_C2C3R()
Thank you very much!
