This is my first contact with NPP.When I try to use CUDA NPP to convert YUVNV12 to BGRHWC, but the conversion fails.Can someone tell me how I should correct my code to make it work.
System:Linux(ubuntu 18.04)
GPU Info(2080Ti CC 7.5)
Below is my code.
#include <cuda_runtime.h>
#include <iostream>
#include <npp.h>
#include <nppi_color_conversion.h>
#include <opencv2/opencv.hpp>
#include <vector>
inline void InitInput(std::vector<unsigned char> &vec)
for (int i = 0; i < vec.size(); i++)
vec[i] = i % 127 + 128;
int main()
int width = 200, height = 600;
std::vector<unsigned char> input_y(width * height);
std::vector<unsigned char> input_uv(width * height / 2);
InitInput(input_y);
InitInput(input_uv);
std::vector<unsigned char> input_yuv;
input_yuv.insert(input_yuv.end(), input_y.begin(), input_y.end());
input_yuv.insert(input_yuv.end(), input_uv.begin(), input_uv.end());
cv::Mat src(height * 3 / 2, width, CV_8UC1, input_yuv.data());
Npp8u *d_src[2], *d_dst;
cudaMalloc(&d_src[0], height * width * sizeof(Npp8u));
cudaMalloc(&d_src[1], height * width / 2 * sizeof(Npp8u));
cudaMalloc(&d_dst, height * width * 3 * sizeof(Npp8u));
cudaMemcpy(d_src[0], input_y.data(), width * height * sizeof(Npp8u), cudaMemcpyHostToDevice);
cudaMemcpy(d_src[1], input_uv.data(), width * height / 2 * sizeof(Npp8u), cudaMemcpyHostToDevice);
NppiSize npp_size = {width, height};
nppiNV12ToBGR_8u_P2C3R(d_src, width, d_dst, width * 3, npp_size);
cv::Mat npp_res(height, width, CV_8UC3);
cudaMemcpy(npp_res.data, d_dst, width * height * 3, cudaMemcpyDeviceToHost);
cv::Mat opencv_res(height, width, CV_8UC3);
cv::cvtColor(src, opencv_res, cv::ColorConversionCodes::COLOR_YUV2BGR_NV21);
int step = height * width * 3;
int cnt = 0;
for (int i = 0; i < width * height * 3; i++)
int npp_num = static_cast<int>(npp_res.data[i]);
int opencv_num = static_cast<int>(opencv_res.data[i]);
if (fabs(npp_num - opencv_num) >= 1.0f)
cnt++;
std::cout << "cnt " << cnt << std::endl;
std::cout << "YUV_I420_To_BGR_HWC int8,error rate: "
<< (float)cnt / step * 100 << "%" << std::endl;
cudaFree(d_src);
cudaFree(d_dst);
return 0;
Error rate near 55%.
Thank you very much!
