Hello All!
I’m trying to call nppiNV12ToBGR_8u_P2C4R to convert my CUeglFrame
to BGR format.
The current frame is in CU_EGL_COLOR_FORMAT_YUV420_SEMIPLANAR_ER
, which I believe to be NV12
CU_EGL_COLOR_FORMAT_YUV420_SEMIPLANAR_ER = 0x26,
Extended Range Y, UV in two surfaces (UV as one surface)
with VU byte ordering, U/V width = 1/2 Y width, U/V height = 1/2 Y height.
So far, I’ve been successful to extract Y
and CrCb
separately.
// Device memory
uchar *d_Y;
uchar *d_CrCb;
uchar *d_BGRA;
// Width, Height
cudaMalloc(&d_Y, sizeof(uchar) * WIDTH * HEIGHT);
// (Width / 2), (Height / 2)
cudaMalloc(&d_CrCb, sizeof(uchar) * WIDTH * HEIGHT / 4);
// Width, Height, 4 channels
cudaMalloc(&d_BGRA, sizeof(uchar) * WIDTH * HEIGHT * 4);
err = cudaMemcpy2DFromArray(d_Y,
WIDTH * sizeof(uchar),
(cudaArray_t)cuY,
0,
0,
HEIGHT,
cudaMemcpyDeviceToDevice);
checkError(err, "cudaMemcpy2DFromArray");
err = cudaMemcpy2DFromArray(d_CrCb,
(WIDTH / 2) * sizeof(uchar),
(cudaArray_t)cuCrCb,
0,
0,
(HEIGHT / 2),
// EVERYHING IS GOOD UNTIL HERE
uchar *pSrc[] = {d_Y, d_CrCb};
NppiSize roi{
.width = static_cast<int>(WIDTH),
.height = static_cast<int>(HEIGHT),
NppStatus npperr = nppiNV12ToBGR_8u_P2C4R(pSrc, WIDTH, d_BGRA, WIDTH, roi);
if (npperr)
printf("%x\n", npperr);
printf("%d\n", npperr);
Memory copies terminate without any error, but it doesn’t when I call NPP function.
The npperr
is -14, which is NPP_STEP_ERROR
, “Step is less or equal zero.”
I’m using width
which is 640.
So my question is,
What is the shape of NV12 in NPP?
The description says it consists of two planes. Checked ✔️
The Y plane is surely height by width. Checked ✔️
The CrCb plane is not clear yet. ❌
