We have used a custom carrier board like images below.
We added msata interface to jetson carrier board.
Is there any additional work needed to use mSATA other than the hardware connector connection?
Thank you.
Thank you.
Hi, you should check with vendor of custom board for this.
This is a carrier board that we made ourselves, not purchased.
Thank you.
What interface is in use here? I remember that we don’t have SATA pin mentioned in the Nano module…?
It’s usbtosata interface.
Thank you.
Then it is a usb device to jetson. May the vendor driver is needed.
