Set enable-frame-type-reporting=true
no impact for decoder
gst-launch-1.0 filesrc location="your misc.h264 path" ! h264parse ! nvv4l2decoder enable-frame-type-reporting=true ! nv3dsink
Can you dump the h264 code stream that causes the stuck?
Hello, the attachment stopped after using the resolution switch in the pipeline below.
appsrc ! h264parse ! nvdec ! appsink # enable-frame-type-reporting=FALSE
The timing of video saving is to obtain the H264
data from the device and first write it to the local file, and then push the data into GstPipeline_appsrc
At the same time, the test pipeline gst-launch-1.0 filesrc location="your misc.h264 path" ! h264parse ! nvv4l2decoder enable-frame-type-reporting=true ! nv3dsink
can be played
test.zip (22.9 MB)
Use the below command dump frame information.
ffprobe -i test.h264 -show_frames -of xml > out.xml
The resolution of frame 224 has changed.
223: <frame media_type="video" stream_index="0" key_frame="0" pkt_duration="40000" pkt_duration_time="0.033333" pkt_pos="11961810" pkt_size="53243" width="1920" height="1440" pix_fmt="yuv420p" pict_type="P" coded_picture_number="227" display_picture_number="0" interlaced_frame="0" top_field_first="0" repeat_pict="0" chroma_location="left"/>
224: <frame media_type="video" stream_index="0" key_frame="1" pkt_duration="40000" pkt_duration_time="0.033333" pkt_pos="12015053" pkt_size="35515" width="1920" height="1080" pix_fmt="yuv420p" pict_type="I" coded_picture_number="228" display_picture_number="0" interlaced_frame="0" top_field_first="0" repeat_pict="0" chroma_location="left"/>
nvv4ldecoder
could be handle it normally.
As your mentioned before, If save to yuv can work normally, Maybe the reason of stucks is appsink
Hello, when I tested the pipeline below, no matter how I cut the resolution, it would not cause the pipeline to be blocked, so I have been unable to determine which element is the problem.
appsrc ! h264parse ! appsink
Just parse h264 stream ? no decoder ?
When the resolution becomes larger, does your appsink
need to realloc memory according to the new video width and height?
I didn’t do anything in the code just read the data in appsink parsing the resolution
static GstFlowReturn appsink_new_sample(GstElement* sink , gpointer* data) {
// std::cout << "appsink sample" << endl;
GstSample* sample;
GstBuffer* buf = NULL;
sample = gst_app_sink_pull_sample(GST_APP_SINK(sink));
if (gst_app_sink_is_eos(GST_APP_SINK(sink))) {
g_print("EOS received in Appsink********\n");
if (sample) {
// std::cout << "appsink 有数据到来" << endl;
buf = gst_sample_get_buffer(sample);
auto caps = gst_sample_get_caps(sample);
if (caps) {
GstStructure* structure = gst_caps_get_structure(caps , 0);
gint width , height;
gst_structure_get_int(structure , "width" , &width);
gst_structure_get_int(structure , "height" , &height);
// g_print("Width: %d, Height: %d\n" , width , height);
USER_LOG_INFO("appsink new sample width:%d , height:%d" , width , height);
// gst_caps_unref(caps);
gst_sample_unref(sample);
return GST_FLOW_OK;
return GST_FLOW_ERROR;
