I need disable boot messages like this thread:
https://devtalk.nvidia.com/default/topic/1027146/how-do-i-disable-boot-messages-and-display-a-custom-splash-screen-/
but u-boot seems no longer exist on the Xavier. How can I do it on Xavier?
Could you try to set this field in tegra194-mb1-soft-fuses-l4t.cfg?
Verbosity = 4; # 0: Disabled: 1: Critical, 2: Error, 3: Warn, 4: Info, 5: Debug
Where can I find tegra194-mb1-soft-fuses-l4t.cfg?
If you’ve flashed, then JetPack/SDK Manager has downloaded the driver package. This will produce:
Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg
This in turn might be copied to:
Linux_for_Tegra/bootloader/tegra194-mb1-soft-fuses-l4t.cfg
However, note that the Xavier is a t186, but often different Tegra devices share or inherit from other Tegra devices. I don’t know if the t194 is correct, but it might be.
I using JetPack-L4T-4.1.1-linux-x64_b57.run
Set
Verbosity = 0; # 0: Disabled: 1: Critical, 2: Error, 3: Warn, 4: Info, 5: Debug
in Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg
then run JetPack-L4T-4.1.1-linux-x64_b57.run
But boot messages didn’t disabled.
Both Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg and
Linux_for_Tegra/bootloader/tegra194-mb1-soft-fuses-l4t.cfg are set.
I run
sudo ./flash.sh jetson-xavier mmcblk0p1
after set Verbosity = 0;
It also no effect about boot messages.
