Description
Whenever we try to do any inference with our model it fails. Something between the lines of allocating buffers or streams fails.
import tensorrt as trt
import numpy as np
import os
import pycuda.driver as cuda
import pycuda.autoinit
class HostDeviceMem(object):
def __init__(self, host_mem, device_mem):
self.host = host_mem
self.device = device_mem
def __str__(self):
return "Host:\n" + str(self.host) + "\nDevice:\n" + str(self.device)
def __repr__(self):
return self.__str__()
class TrtModel:
def __init__(self,engine_path,max_batch_size=1,dtype=np.float32):
self.engine_path = engine_path
self.dtype = dtype
self.logger = trt.Logger(trt.Logger.WARNING)
self.runtime = trt.Runtime(self.logger)
self.engine = self.load_engine(self.runtime, self.engine_path)
self.max_batch_size = max_batch_size
self.inputs, self.outputs, self.bindings, self.stream = self.allocate_buffers()
self.context = self.engine.create_execution_context()
@staticmethod
def load_engine(trt_runtime, engine_path):
trt.init_libnvinfer_plugins(None, "")
with open(engine_path, 'rb') as f:
engine_data = f.read()
engine = trt_runtime.deserialize_cuda_engine(engine_data)
return engine
def allocate_buffers(self):
inputs = []
outputs = []
bindings = []
stream = cuda.Stream()
for binding in self.engine:
size = trt.volume(self.engine.get_binding_shape(binding)) * self.max_batch_size
host_mem = cuda.pagelocked_empty(size, self.dtype)
device_mem = cuda.mem_alloc(host_mem.nbytes)
bindings.append(int(device_mem))
if self.engine.binding_is_input(binding):
inputs.append(HostDeviceMem(host_mem, device_mem))
else:
outputs.append(HostDeviceMem(host_mem, device_mem))
return inputs, outputs, bindings, stream
def __call__(self,x:np.ndarray,batch_size=2):
x = x.astype(self.dtype)
np.copyto(self.inputs[0].host,x.ravel())
for inp in self.inputs:
cuda.memcpy_htod_async(inp.device, inp.host, self.stream)
self.context.execute_async(batch_size=batch_size, bindings=self.bindings, stream_handle=self.stream.handle)
for out in self.outputs:
cuda.memcpy_dtoh_async(out.host, out.device, self.stream)
self.stream.synchronize()
return [out.host.reshape(batch_size,-1) for out in self.outputs]
if __name__ == "__main__":
batch_size = 1
trt_engine_path = "model.plan"
model = TrtModel(trt_engine_path)
shape = model.engine.get_binding_shape(0)
data = np.random.randint(0,255,(batch_size,*shape[1:]))/255
result = model(data,batch_size)
Environment
TensorRT Version:
nvcr.io/nvidia/tensorrt:22.05-py3
GPU Type: RTX 3090
Nvidia Driver Version: 5.15
NVIDIA-SMI 515.86.01 Driver Version: 515.86.01 CUDA Version: 11.7
CUDA Version:
CUDNN Version:
Operating System + Version: ubuntu 2004
Python Version (if applicable): 3.9
TensorFlow Version (if applicable):
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag):
Relevant Files
Please attach or include links to any models, data, files, or scripts necessary to reproduce your issue. (Github repo, Google Drive, Dropbox, etc.)
Steps To Reproduce
Please include:
- Exact steps/commands to build your repro
- Exact steps/commands to run your repro
- Full traceback of errors encountered
