Hi , I did the following conversion:
keras(.h5) ----> tensorflow(.pb) ----> onnx ----> tensorrt(.trt)
I haven’t seen an obvious way to predict with tensorrt model(.trt) and my pre-trained model is multi view CNN so I have multiple input for each prediction .
Do you have any code example that shows me how to predict in this case with trt model ?(I’m using jetson nano)
thanks for your attention .
Environment
TensorRT Version : 7.1.3.0
CUDA Version : 10.2.89
CUDNN Version : 8.0.0.180
Operating System + Version : ubuntu 18.04
Python Version (if applicable) : 3.6.9
TensorFlow Version (if applicable) : 2.3.1
You can inference TensorRT model with the below sample.
inference.py
import cv2
import time
import numpy as np
import tensorrt as trt
import pycuda.autoinit
import pycuda.driver as cuda
EXPLICIT_BATCH = 1 << (int)(trt.NetworkDefinitionCreationFlag.EXPLICIT_BATCH)
TRT_LOGGER = trt.Logger(trt.Logger.INFO)
runtime = trt.Runtime(TRT_LOGGER)
host_inputs = []
cuda_inputs = []
host_outputs = []
cuda_outputs = []
bindings = []
def Inference(engine):
image = cv2.imread("/usr/src/tensorrt/data/resnet50/airliner.ppm")
image = (2.0 / 255.0) * image.transpose((2, 0, 1)) - 1.0
np.copyto(host_inputs[0], image.ravel())
stream = cuda.Stream()
context = engine.create_execution_context()
start_time = time.time()
cuda.memcpy_htod_async(cuda_inputs[0], host_inputs[0], stream)
context.execute_async(bindings=bindings, stream_handle=stream.handle)
cuda.memcpy_dtoh_async(host_outputs[0], cuda_outputs[0], stream)
stream.synchronize()
print("execute times "+str(time.time()-start_time))
output = host_outputs[0].reshape(np.concatenate(([1],engine.get_binding_shape(1))))
print(np.argmax(output))
def PrepareEngine():
with open('./trt.plan', 'rb') as f:
buf = f.read()
engine = runtime.deserialize_cuda_engine(buf)
# create buffer
for binding in engine:
size = trt.volume(engine.get_binding_shape(binding)) * engine.max_batch_size
host_mem = cuda.pagelocked_empty(shape=[size],dtype=np.float32)
cuda_mem = cuda.mem_alloc(host_mem.nbytes)
bindings.append(int(cuda_mem))
if engine.binding_is_input(binding):
host_inputs.append(host_mem)
cuda_inputs.append(cuda_mem)
else:
host_outputs.append(host_mem)
cuda_outputs.append(cuda_mem)
return engine
if __name__ == "__main__":
engine = PrepareEngine()
Inference(engine)
For example:
$ /usr/src/tensorrt/bin/trtexec --onnx=/usr/src/tensorrt/data/resnet50/ResNet50.onnx --saveEngine=trt.plan
$ python3 inference.py
For your use case, you may need to update the input buffer size to multiple cases.
Ex. host_inputs[0], host_inputs[1], host_inputs[2], …
