I have retrained model using the link. I have got onnx file and the file is used to create engine file and works as I expected. For the whole example I used this repo.
For inference in realtime, I want to avoid using the above repo. So, I decided to run onnx file to run on TRT runtime.
For that I used below code.
import cv2
import time
import numpy as np
import tensorrt as trt
import pycuda.autoinit
import pycuda.driver as cuda
EXPLICIT_BATCH = 1 << (int)(trt.NetworkDefinitionCreationFlag.EXPLICIT_BATCH)
TRT_LOGGER = trt.Logger(trt.Logger.INFO)
runtime = trt.Runtime(TRT_LOGGER)
host_inputs = []
cuda_inputs = []
host_outputs = []
cuda_outputs = []
bindings = []
def Inference(engine):
image = cv2.imread("/usr/src/tensorrt/data/resnet50/airliner.ppm")
np.copyto(host_inputs[0], image)
stream = cuda.Stream()
context = engine.create_execution_context()
start_time = time.time()
cuda.memcpy_htod_async(cuda_inputs[0], host_inputs[0], stream)
context.execute_async(bindings=bindings, stream_handle=stream.handle)
cuda.memcpy_dtoh_async(host_outputs[0], cuda_outputs[0], stream)
stream.synchronize()
print("execute times "+str(time.time()-start_time))
output = host_outputs[0].reshape(np.concatenate(([1],engine.get_binding_shape(1))))
print(np.argmax(output))
def PrepareEngine():
with trt.Builder(TRT_LOGGER) as builder, builder.create_network(EXPLICIT_BATCH) as network, trt.OnnxParser(network, TRT_LOGGER) as parser:
builder.max_workspace_size = 1 << 30
with open('/usr/src/tensorrt/data/resnet50/ResNet50.onnx', 'rb') as model:
if not parser.parse(model.read()):
print ('ERROR: Failed to parse the ONNX file.')
for error in range(parser.num_errors):
print (parser.get_error(error))
engine = builder.build_cuda_engine(network)
# create buffer
for binding in engine:
size = trt.volume(engine.get_binding_shape(binding)) * engine.max_batch_size
host_mem = cuda.pagelocked_empty(shape=[size],dtype=np.float32)
cuda_mem = cuda.mem_alloc(host_mem.nbytes)
bindings.append(int(cuda_mem))
if engine.binding_is_input(binding):
host_inputs.append(host_mem)
cuda_inputs.append(cuda_mem)
else:
host_outputs.append(host_mem)
cuda_outputs.append(cuda_mem)
return engine
if __name__ == "__main__":
engine = PrepareEngine()
Inference(engine)
I am getting error in pre-process stage.
Below is my stack error.
TensorRT] WARNING: onnx2trt_utils.cpp:220: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[TensorRT] WARNING: onnx2trt_utils.cpp:246: One or more weights outside the range of INT32 was clamped
[TensorRT] INFO: Detected 1 inputs and 4 output network tensors.
File “main.py”, line 67, in
Inference(engine)
File “main.py”, line 23, in Inference
np.copyto(host_inputs[0], img_data)
File “<array_function internals>”, line 6, in copyto
ValueError: could not broadcast input array from shape (224,224,3) into shape (270000)
Can someone help me how to resolve the issue?
