Dear all,
I was converting the onnx model to TensorRT model. I could successfully convert to TensorRT model by FP32 and do the TensorRT influence.
However, if I used the FP16, then I got error.
I used the onnx2trt tool.
The error output :
Input filename: model.onnx
ONNX IR version: 0.0.4
Opset version: 10
Producer name: pytorch
Producer version: 1.3
Domain:
Model version: 0
Doc string:
Parsing model
[2020-04-30 05:44:47 WARNING] Calling isShapeTensor before the entire network is constructed may result in an inaccurate result.
Building TensorRT engine, FP16 available:1
Max batch size: 1
Max workspace size: 1024 MiB
[2020-04-30 06:31:54 ERROR] ../builder/cudnnBuilderWeightConverters.cpp (482) - Misc Error in operator(): 1 (Weights are outside of fp16 range. A possible fix is to retrain the model with regularization to bring the magnitude of the weights down.)
terminate called after throwing an instance of 'std::runtime_error'
what(): Failed to create object
Aborted (core dumped)
If I use the build_engine function by FP32, then I got this error message.
File "embedmask_engine_2.py", line 81, in <module>
batch_size=1)
File "embedmask_engine_2.py", line 18, in build_engine
if trt_engine_datatype == trt.float16: # mrcnn add chieh
TypeError: __eq__(): incompatible function arguments. The following argument types are supported:
1. (self: tensorrt.tensorrt.DataType, arg0: tensorrt.tensorrt.DataType) -> bool
Invoked with: DataType.HALF, 32
I am sure my script which can implement successfully on Desktop Linux Ubuntu 18.04 to generate the TRT engine.
But I cannot run it on TX2. (Use the same onnx model.)
[TX2] Environment setting
ubuntu version: 18.04
python3 version: 3.6.9
Tensorflow version: 1.15
TensorRT version: 6.0.1.10
CUDA version: 10.0.326
nvcc: NVIDIA (R) Cuda compiler driver Copyright (c) 2005-2019 NVIDIA Corporation Built on Mon_Mar_11_22:13:24_CDT_2019 Cuda compilation tools, release 10.0, V10.0.326
cuDNN version: 7.6.3
docker version: Docker version 18.09.7, build 2d0083d
How can I fix it?
Thank you!!
